Out of ROM, A segment or the program is too large
TheGaut
PostPosted: Mon Mar 15, 2004 10:17 am     Reply with quote
When i compile i get this error: Out of ROM, A segment or the program is too large.
I try to use #seperate before my fonctions but my stack is full.
I use the Pic 16F877.
Any suggestion????
Thank you.
Re: Out of ROM, A segment or the program is too large
PostPosted: Mon Mar 15, 2004 2:02 pm     Reply with quote
Any suggestion????
Thank you.
It _may_ be possible to improve things, by looking at the memory ueage map, and making some functions that are currently seperate 'inline', and only using seperate where needed to get the required splits. However the easiest solution is probably to use a 18F452 instead...
