		| Author | Message |
		| pyroboy123
				| SLAVE I2C Not working |
				|  Posted: Tue Mar 16, 2004 10:33 am |   |
				| Hey all, this is my code for the slave device:
 #fuses	MCLR,HS,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG
 #use	delay(clock=20000000, RESTART_WDT)
 #use	i2c(SLAVE, SDA=PIN_B1, SCL=PIN_B4,address=0xB0)
 #byte		Port_a = 5
 #int_ssp
 void ssp_interrupt() {
 Port_a = 0xFF;
 set_tris_a(0);
 enable_interrupts(INT_SSP);
 while (TRUE) {
 restart_wdt();
 My master device works because I can get info to and from an eeprom.
 I have just added these lines in the masters code :
 i2c_start();
 i2c_write(0xB0);
 i2c_stop();
 Could anyone tell me WHY my led on PORT_A on the slave device is not turning on ???
 Thx
		| agrj
				|  Posted: Tue Mar 16, 2004 12:22 pm |   |
				| Hi,
 2 things:
 1 - CCS said in their manual that you have to use the directive force_hw when using I2C in slave mode
 2 - These pins that you are using are the correct SDA and SCL? (what processor are you using?)
 I hope it helps
 Dinho
		| pyroboy123
				| more info |
				|  Posted: Tue Mar 16, 2004 12:34 pm |   |
				| nope all you said I have done already.
 I'm using a 16F87 and I have tried doing the FORCE_HW and that doesnt change anything either.
 Now I'm using the ICD2 to look at my registers ....
 I put a breakpoint on one of the first lines.
 When I look at SSPCON it is 0
 This means that the #use i2c doesnt work ?
		| agrj
				|  Posted: Wed Mar 17, 2004 6:51 am |   |
				| what are the value of the others registers:
 SSPADD and SSPSTAT?
 thanks
