10 second delay & 3 hours delay
edi
PostPosted: Mon Mar 15, 2004 8:41 am     Reply with quote
1. I want to run my software and after 10 seconds to activate something.
Can someone recommend on a way to get a 10 seconds delay, while the program is still running.
2. What is the best way to achieve 3 hours delay?
Edi
Neutone
PostPosted: Mon Mar 15, 2004 8:57 am     Reply with quote
What kind of accuracy do you need?
edi
PostPosted: Mon Mar 15, 2004 10:02 am     Reply with quote
The accuracy is not so important.
For the 10 seconds +-0.5s is ok
For the 3 hours +-10s is ok
thanks,
Edi
Neutone
PostPosted: Mon Mar 15, 2004 10:15 am     Reply with quote
What chip are you using? What timers are not already used? What is the xtal freq?
edi
PostPosted: Mon Mar 15, 2004 1:44 pm     Reply with quote
I'm using the 16f819 or 16f877.
Xtal = 20MHz
Timer1 in use.
There is need for WDT.
tnx,
Edi
Neutone
PostPosted: Mon Mar 15, 2004 2:47 pm     Reply with quote
This is how I would handel it.
Try this.
int1  Clock_Been_Initialized=0;
Int16 Miliseconds;
Int16 Seconds;
int16 Three_Hour;
int8ten_Seconds;
int1  Second_Tick=0;
int1  ten_second_Tick=0;
int1 three_Hour_Tick=0;
// Global Real Time Clock Information
#int_TIMER2                                                 // Clock interrupt adjusted to occurs ~ 1ms
void TIMER2_isr()
{  Miliseconds++;
   if(Miliseconds>999)
   {  Miliseconds=0;
      Seconds++;
      Second_Tick=1;
*    Service Hardware Modules                              *
#inline
void Clock_Service(void)
{  if(!Clock_Been_Initialized)
   {  setup_timer_2(T2_DIV_BY_4,249,5);                     // Set 1mS period
      Seconds=0;
      Clock_Been_Initialized=1;
   if(Second_Tick)
   {  Second_Tick=0;
      if(--ten_Seconds==0)
      {   ten_Seconds=10;
           ten_second_Tick=1;
      if(--Three_Hour==0)
      {   Three_Hour=10800;
           three_Hour_Tick=1;
wedilo
PostPosted: Tue Mar 16, 2004 2:28 am     Reply with quote
Hello Neutone,
I would like to understand the problematic nature of a timer.
In your code I can see, that the isr will be called every millisecond.
Is the performance ok? Is there also enough time for other actions like controlling etc. ?
In my sources I call it every 100ms, but I would like to take your code. It looks reliable. Sorry, but I'm doubtful.
73 Sven
Neutone
PostPosted: Tue Mar 16, 2004 9:09 am     Reply with quote
wedilo wrote:
Hello Neutone,
73 Sven
edi specifies Xtal = 20MHz
That means that in 1 mS there are 5000 instruction cycles. Vectoring to an interupt take ~100 insctuction cycles. That means that 2% of total processor time is spent tracking time. It really just depends on your processing requirements.
edi
PostPosted: Tue Mar 16, 2004 1:10 pm     Reply with quote
Neutone,
Thanks a lot it's look excellent.
Do you have also a good WDT function that you can post.
Edi.
Neutone
PostPosted: Tue Mar 16, 2004 3:19 pm     Reply with quote
edi wrote:
Neutone,
Edi.
It's really an application specific thing. Maybe just add restart WDT within the clock service routine not the interupt. If something locks up the processor will restart.
edi
PostPosted: Tue Mar 16, 2004 11:38 pm     Reply with quote
ok, I'll try.
Edi
wedilo
PostPosted: Wed Mar 17, 2004 1:26 am     Reply with quote
Hello Neutone,
From this point of view it looks clear. Thank you Embarassed
73 Sven
