Struct of structs
treitmey
Struct of structs
PostPosted: Tue Mar 09, 2004 9:42 am     Reply with quote
Hi All
Does a struct that contains structs all have to fit into a single bank of memory?
I seem to run out to memory with an aray of structs or struct of structs, but if I instantiate them seperatly they compile.
I am using pcm 3.184/mplab6.40 and a PIC 16F877A
struct  packet{     // Header(first 5 bytes), data(up to 26 bytes), chksum
  BYTE rx_DA;       // Desgination address recieved
  BYTE data_size;   // Number of bytes. NOT counting header and chksum
  BYTE function;    // Function code of packet
  BYTE sequence;    // This is the n packet of the total
  BYTE packet_total;// Total number of packets in message
  BYTE data[MAXDATA];// Data, size is the number of bytes
  BYTE rx_chksum;    // A checksum over the entire pkt.
  BYTE calc_chksum;  // This checksum is calculated as data is recieved
  BOOLEAN done; // FLAG, 1=all data has been recieved.
  BOOLEAN good; // FLAG, 1=chksum is corect AND dest==my_address, fctn code is a valid function
};            // Define 4 packets of buffer space. pkt[0]->pkt[3]
  struct packet pkt0;
  struct packet pkt1;
  struct packet pkt2;
Has anyone done something simulare to this?
I want to define a buffer with 3 packets.
SteveP
Structs in Structs
PostPosted: Fri Mar 26, 2004 11:07 am     Reply with quote
I have a similar programmin requirement at the moment and have found that the limit is caused by the RAM block size limit. Nothing can be done but define each struct individually as you have done.
Not very elegant, but gets the job done.
Steve.
Haplo
PostPosted: Fri Mar 26, 2004 5:34 pm     Reply with quote
By looking at the first line of your code your struct size is 31 bytes (although the actual struct appears to be bigger). The biggest memory bank is 96 bytes, so as long as you keep your struct size under 32 you should be able to place an array of 3 in one bank. Try this:
struct packet pkt[3];
#locate pkt=0x190 //Put the array at the very beginning of bank 2
