Pointer to function using #ASM
Beppe
PostPosted: Tue Mar 02, 2004 5:42 am     Reply with quote
I read is not possible in CCS to obtain a pointer to a function.
So I thought I could obtain it by an assembly sobroutine and using the symbol table... i.e.:
void
my_function(){
main() {
#ASM
MOVFF my_function, FSR0L
//or something similar
#ASM
I tried this but compiler reports the following error: "Expression must evaluate to a constant"... I can't understand why! I looked at the symbol table and to the symbol my_function is rightly assigned the program memory address of th function!
Could anyone help me, please?
Thanks!! Sad
mpfj
PostPosted: Tue Mar 02, 2004 6:03 am     Reply with quote
You're almost there ... !!
What you can do is use the #org directive to force the function to a known location .. e.g.
#org 0x8000, 0x81ff
void function(void) {
You can then use the following to call the function ...
#asm
   call 0x8000
#endasm
The downside is that you can't pass parameters, although you can just make them globals and the you're away !!
Re: Pointer to function using #ASM
PostPosted: Tue Mar 02, 2004 11:08 am     Reply with quote
void
my_function(){
main() {
#ASM
#ASM
Thanks!! Sad
Actually pointers to functions, _are_ now supported (though with significant 'caveats').
