setup_timer_2(??,??,??) with Neoton zero drift RTC
Izolator
View user's profile Send private message ICQ Number
PostPosted: Mon Feb 23, 2004 3:29 pm     Reply with quote
Hi Guys,
I'm using a slightly minimized version of Neotone's old code, cutting out month, years and leapyears.
//RTC variables
int32 const xtl = 19660800;
int32 clock = xtl;
int8 days=0,hours=0,minutes=0,seconds=0;
int1 leapyear=0,tick=0;
// 0.83mS resolution with my xtl value
// -=Process Zero Drift Real Time Clock Information=-
// Decrement cycles per interupt
// Increment seconds counter, Set 1 second flag, Add number of ticks per second to clock
// Increment minutes counter
// Increment hours counter
// Increment days counter
#int_TIMER2
void TIMER2_isr() { clock -= 16384;
if(clock < 16384) {seconds++;clock += xtl;Tick= 1;
if(seconds == 60) {minutes++;seconds = 0;
if(minutes == 60) {hours++;minutes = 0;
if(hours == 24) {days++;hours= 0;
Problem:
As I am a total newbie with Timers & Interrupt I just recently discovered that the interrupt needs to be setup and enabled. I dont understand the math of it ?!?!?
I'm using:
20Mhz osc. quartz
Pic16F877
PCM 3.173
...what do I do to make the routine work as intended, with my crystal ?
I tried with:
setup_timer_2(T2_DIV_BY_16,0xff,1);
but that makes it count a little too fast: some 30sec in 20 min, hmm.
Keep in mind that to me the 3 variables are just numbers and I guessed at random to test it....not the correct way I know.
main() {
setup_timer_2(??,??,??);         // what do I put instead of the ??'s to make Neotrons code behave as intended, a RTC that puts secs, mins, hours....
enable_interrupts(int_timer2);
enable_interrupts(global);
while(1) {
side question:
what does the dear mr. Neotone mean by the following:
1) // 0.83mS resolution with my xtl value
2) int32 const xtl = 19660800; => do I need to change this to 20000000 ?
Thanks for you assistance guys, this is making my head hurt Sad
BR
Rasmus 'Izolator'
Neutone
PostPosted: Mon Feb 23, 2004 4:40 pm     Reply with quote
I think this has better comments. 19660800 is a frequency that can be divided to get the most common baud rates. It's the frequency of the crystle I use.
*    Initialize RTC                          *
void Initialize_RTC(void)
{  Ticker = XTAL_FREQUENCY;
   setup_timer_2 ( T2_DIV_BY_4, 0xff, 4 );   // initialize 8 bit counter/timer 2 to interupt every 16384 clock cycles
   enable_interrupts( INT_TIMER2 );          // Start RTC
// Global Real Time Clock Information
#int_TIMER2                                  // Clock interrupt adjusted to occurs ~ 1ms
void TIMER2_isr()                            //  -=Process Zero Drift Real Time Clock Information=-
{  tickmSec = 1;                             // set each MS very approximately
   Ticker -= 16384;                          // Decrement ticker by clocks per interupt
   if ( Ticker < 16384 )                     // If second has expired
   {  Ticker += XTAL_FREQUENCY;              // Increment ticker by clocks per second
      second++;                              // Increment number of seconds
      tickSec = 1;                           // set each Second very accuratly
Izolator
PostPosted: Mon Feb 23, 2004 4:43 pm     Reply with quote
Thankyou good Sir,
It seems to work right out of the box.
Bless you, I might still pass my exam Cool
BR
Rasmus 'Izolator'
