		| Author | Message |
		| Izolator
				| setup_timer_2(??,??,??) with Neoton zero drift RTC |
				|  Posted: Mon Feb 23, 2004 3:29 pm |   |
				| Hi Guys,
 I'm using a slightly minimized version of Neotone's old code, cutting out month, years and leapyears.
  	  | Code: |  	  | //RTC variables
 int32 const xtl = 19660800;
 int32 clock = xtl;
 int8 days=0,hours=0,minutes=0,seconds=0;
 int1 leapyear=0,tick=0;
 // 0.83mS resolution with my xtl value
 // -=Process Zero Drift Real Time Clock Information=-
 // Decrement cycles per interupt
 // Increment seconds counter, Set 1 second flag, Add number of ticks per second to clock
 // Increment minutes counter
 // Increment hours counter
 // Increment days counter
 #int_TIMER2
 void TIMER2_isr() { clock -= 16384;
 if(clock < 16384) {seconds++;clock += xtl;Tick= 1;
 if(seconds == 60) {minutes++;seconds = 0;
 if(minutes == 60) {hours++;minutes = 0;
 if(hours == 24) {days++;hours= 0;
 Problem:
 As I am a total newbie with Timers & Interrupt I just recently discovered that the interrupt needs to be setup and enabled. I dont understand the math of it ?!?!?
 I'm using:
 20Mhz osc. quartz
 Pic16F877
 PCM 3.173
 ...what do I do to make the routine work as intended, with my crystal ?
 I tried with:
 setup_timer_2(T2_DIV_BY_16,0xff,1);
 but that makes it count a little too fast: some 30sec in 20 min, hmm.
 Keep in mind that to me the 3 variables are just numbers and I guessed at random to test it....not the correct way I know.
  	  | Code: |  	  |
 main() {
 setup_timer_2(??,??,??);         // what do I put instead of the ??'s to make Neotrons code behave as intended, a RTC that puts secs, mins, hours....
 enable_interrupts(int_timer2);
 enable_interrupts(global);
 while(1) {
 side question:
 what does the dear mr. Neotone mean by the following:
 1) // 0.83mS resolution with my xtl value
 2) int32 const xtl = 19660800; => do I need to change this to 20000000 ?
 Thanks for you assistance guys, this is making my head hurt
 BR
 Rasmus 'Izolator'
		| Neutone
				|  Posted: Mon Feb 23, 2004 4:40 pm |   |
				| I think this has better comments. 19660800 is a frequency that can be divided to get the most common baud rates. It's the frequency of the crystle I use.
  	  | Code: |  	  | /*********************************************
 *    Initialize RTC                          *
 void Initialize_RTC(void)
 {  Ticker = XTAL_FREQUENCY;
 setup_timer_2 ( T2_DIV_BY_4, 0xff, 4 );   // initialize 8 bit counter/timer 2 to interupt every 16384 clock cycles
 enable_interrupts( INT_TIMER2 );          // Start RTC
 // Global Real Time Clock Information
 #int_TIMER2                                  // Clock interrupt adjusted to occurs ~ 1ms
 void TIMER2_isr()                            //  -=Process Zero Drift Real Time Clock Information=-
 {  tickmSec = 1;                             // set each MS very approximately
 Ticker -= 16384;                          // Decrement ticker by clocks per interupt
 if ( Ticker < 16384 )                     // If second has expired
 {  Ticker += XTAL_FREQUENCY;              // Increment ticker by clocks per second
 second++;                              // Increment number of seconds
 tickSec = 1;                           // set each Second very accuratly
		| Izolator
				|  Posted: Mon Feb 23, 2004 4:43 pm |   |
				| Thankyou good Sir,
 It seems to work right out of the box.
 Bless you, I might still pass my exam
 BR
 Rasmus 'Izolator'
 | You cannot post new topics in this forum You cannot reply to topics in this forum
