		| Author | Message |
		| tavioman
				| debug/release versions |
				|  Posted: Fri Nov 02, 2007 1:33 pm |   |
				| Hi all. Can anybody point me to way of doing printf in debug version with a macro?
 The same macro in "release" version would do nothing?
 It's possible do do this with CCS C?
 Thank you.
		| Humberto
				|  Posted: Fri Nov 02, 2007 2:49 pm |   |
				| Did you try with #ifdef preprocessor directives? I can“t fully understand what do you need, please could you write an example of
 what do you want to show/hide while in "debugg mode or in "release mode"?
 Humberto
		| tavioman
				|  Posted: Fri Nov 02, 2007 4:08 pm |   |
				| A macro.
  	  | Code: |  	  | trace("Something %d, else %Ld", x, y); |
 that in release just won't do anything...
		| PCM programmer
				|  Posted: Fri Nov 02, 2007 4:33 pm |   |
				| Try this.  It uses a debug macro from the CCS file Ex_Macro.c.
  	  | Code: |  	  | #include <16F877.H> #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use delay(clock = 4000000)
 //#define DEBUG 1
 #ifdef DEBUG
 #define debug_printf(x)   printf("%s variable value is %d\r\n",#x,x);
 #else
 #endif
 char c;
 c = 0x55;
 debug_printf(c);
		| tavioman
				|  Posted: Sat Nov 03, 2007 12:44 am |   |
				| I wish to be more generic like:  	  | Code: |  	  | trace("This is debug value no. %u with address %u", value, address);
 trace("Just a line");
 trace("Three numbers: %u, %u, %u", number1, number2, number3);
 I believe this can be done with va_arg, etc.
 I've never worked with this, and I don't know the usage....
