		| Author | Message |
		| jt06
				| Does anyone could help me? (Beginner in 18F family) |
				|  Posted: Thu Nov 01, 2007 2:57 am |   |
				| Hi,
 Absolute beginner in programming the family PIC 18F.
 For starting, I try to have 2 alternatives blinkings LED (one on port A.0 and the second on Port E.0).
 This code tested on a 16F877a is OK.
 I am not able to migrate this simplest code on a 18F4620 (or a 18F4550)!!!
 I think that the problem is in fuse configuration?
 Below the fabulous code:
 Many thank's in advance for your help.
 Regards,
 Jo
  	  | Quote: |  	  | #include <18F4620.H> #fuses  HS,NOWDT,NOPROTECT
 #byte portA=0x80                      // Port A Address
 #byte portE=0x84                      // Port E Address
 #bit oLed0 = PortA.0
 #bit oLed1 = PortE.0
 delay_ms(15);
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 SET_TRIS_A(0x00);                 // Port A Output
 SET_TRIS_E(0x00);                 // Port E Output
 oLed0 = 0;                        // LED 0 ON
 oLed1 = 1;                        // LED 1 OFF
 oLed0 = 1;                        // LED 0 OFF
 oLed1 = 0;                        // LED 1 ON
		| PCM programmer
				|  Posted: Thu Nov 01, 2007 3:04 am |   |
				|  	  | Quote: |  	  | #byte portA=0x80 // Port A Address #byte portE=0x84 // Port E Address
 Look in the PIC data sheet in this section:
  	  | Quote: |  	  | TABLE 5-1: SPECIAL FUNCTION REGISTER MAP |
 Compare the Port addresses above, to the addresses in the data sheet.
		| Humberto
				|  Posted: Thu Nov 01, 2007 8:33 am |   |
				|  	  | Quote: |  	  | Absolute beginner in programming the family PIC 18F.
 If you are a beginner in programing MCU, it is a good practice to read and understand
 the manufacturer info published in Datasheets. Are you aware that there is a big
 difference between both MCU? Hence it is improbable that the code that was running
 in the 16F would run in the 18F. The PIC18F4620 has a complex architecture
 compared with the 16F.
 It is a good practice to shut down the modules that is not in use.
 Most of this is done by the Compiler in background, but as a programmer you are the
 responsible of the generated code, not the tools that you are using.
 I suggest you to be explicit while coding, do not assume that somebody will do it for you.
 Following is an example of what I mean.
  	  | Code: |  	  | #include <18F4620.h>
 #device adc=8
 #FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
 #FUSES HS                       //High speed Osc (> 4mhz)
 #FUSES BORV28                   //Brownout reset at 2.8V
 #FUSES NOLVP                    //No Low Voltage Programming on B3(PIC16) or B5(PIC18)
 #FUSES NOWRTD                   //Data EEPROM not write protected
 #FUSES NOEBTR                   //Memory not protected from table reads
 #FUSES NOCPB                    //No Boot Block code protection
 #FUSES NOEBTRB                  //Boot block not protected from table reads
 #FUSES NOWRTC                   //configuration not registers write protected
 #FUSES NOWRTB                   //Boot block not write protected
 #FUSES FCMEN                    //Fail-safe clock monitor enabled
 #FUSES XINST                    //Extended set extension and Indexed Addressing mode enabled
 #FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
 #FUSES LPT1OSC                  //Timer1 configured for low-power operation
 #FUSES MCLR                     //Master Clear pin enabled
 setup_psp(PSP_DISABLED);
 setup_spi(SPI_SS_DISABLED);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 output_high(PIN_A0);
 output_low(PIN_E0);
 output_toggle(PIN_A0);
 output_toggle(PIN_E0);
 Humberto
		| rnielsen
				|  Posted: Thu Nov 01, 2007 9:56 am |   |
				| Plus one thing to know, the set_tris command is useless unless fast_io is stated.  At least that's what the help file states. |  |
		| SherpaDoug
				|  Posted: Thu Nov 01, 2007 11:38 am |   |
				|  	  | rnielsen wrote: |  	  | Plus one thing to know, the set_tris command is useless unless fast_io is stated.  At least that's what the help file states. |
 I would say the set_tris command is UNNECESSARY unless you are using fast_io.
 The search for better is endless.  Instead simply find very good and get the job done.
		| jt06
				|  Posted: Sat Nov 03, 2007 1:00 am |   |
				|  	  | PCM programmer wrote: |  	  |  	  | Quote: |  	  | #byte portA=0x80 // Port A Address #byte portE=0x84 // Port E Address
 Many thank's for that.
 Regards
		| jt06
				|  Posted: Sat Nov 03, 2007 2:20 am |   |
				| Thanks to everyone |  |
