Jeremy Ragsdale Guest
| Help me with ADC output Please ?????? |
Posted: Wed Feb 19, 2003 7:59 am |
I have a 10 bit ADC setup on a 16F876, the output goes form
0-1024 depending on Vref, this much I get. the problem is that I want to sen out 0006 if the adc reads 6 but at the moment I am sending 6. Can anyone advise me on how to do this. I have tried
printf("Sensor 1 reads \%4ld",sensor1);
but this doesn't seem to work??
Help me Please
#include <16f876.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,PUT
#device ADC=10
#use Delay(Clock=4000000)
#use rs232(baud=19200,xmit=pin_c6,rcv=pin_c7,parity=n,bits=8)
long sensor1,sensor2,sensor3,sensor4;
setup_adc(adc_clock_div_8);
setup_adc_ports(all_analog);
set_adc_channel(0);
delay_us(25);
sensor1 = read_adc();
printf("Sensor 1 reads \%ld",sensor1);
set_adc_channel(1);
delay_us(25);
sensor2 = read_adc();
printf("Sensor 2 reads \%ld",sensor2);
set_adc_channel(4);
delay_us(25);
printf("Sensor 3 reads \%ld",sensor3);
set_adc_channel(3);
delay_us(25);
sensor4 = read_adc();
printf("Sensor 4 reads \%ld",sensor4);
___________________________
Original Post ID: 11870 |
Eric Minbiole Guest
| Re: Help me with ADC output Please ?????? |
Posted: Wed Feb 19, 2003 8:59 am |
:=I have a 10 bit ADC setup on a 16F876, the output goes form
:=0-1024 depending on Vref, this much I get. the problem is that I want to sen out 0006 if the adc reads 6 but at the moment I am sending 6. Can anyone advise me on how to do this. I have tried
:=printf("Sensor 1 reads \%4ld",sensor1);
Try
printf("Sensor 1 reads \%04lu",sensor1);
instead. The 0 tells printf to include leading zeros. The lu (instead of ld) is for unsigned integers.
Original Post ID: 11876 |
R.J.Hamlett Guest
Posted: Wed Feb 19, 2003 9:09 am |
:=but this doesn't seem to work??
This was fixed only a few compiler versions ago. If you have an older compiler (with the problem), then you have to 'bodge' the solution, by printing the output to a string, and then adding the required leading zeros. So:
printf("Sensor 1 reads ");
sprintf(opstring,"\%ld",sensor1);
count=strlen(opstring);
while (count++<4) putc('0');
printf("\%s",opstring);
Obviously you have to have an integer 'count', and a suitable string 'opstring' declared.
Easiest thing really is to get a latter compiler.
:=Help me Please
:=#include <16f876.h>
:=#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,PUT
:=#device ADC=10
:=#use Delay(Clock=4000000)
:=#use rs232(baud=19200,xmit=pin_c6,rcv=pin_c7,parity=n,bits=8)
:=void main(void)
:= long sensor1,sensor2,sensor3,sensor4;
:= setup_adc(adc_clock_div_8);
:= setup_adc_ports(all_analog);
:= while(1)
:= set_adc_channel(0);
:= delay_us(25);
:= sensor1 = read_adc();
:= printf("Sensor 1 reads \%ld",sensor1);
:= set_adc_channel(1);
:= delay_us(25);
:= sensor2 = read_adc();
:= printf("Sensor 2 reads \%ld",sensor2);
:= set_adc_channel(4);
:= delay_us(25);
:= printf("Sensor 3 reads \%ld",sensor3);
:= set_adc_channel(3);
:= delay_us(25);
:= sensor4 = read_adc();
:= printf("Sensor 4 reads \%ld",sensor4);
:= delay_ms(500);
Original Post ID: 11877 |
