Analog to Digital Accuracy 16F819 10Bit.
Freddie
PostPosted: Mon Feb 09, 2004 10:06 am     Reply with quote
I'm using a 16F819 for the first time, I usually use the 16F876. With the code below I'm taking 10 AtoD readings and computing the average. With RA0 connected to ground the AtoD value is 0x00 as expected. When RA0 is connected directly to Vdd (same trace as is powering the PIC) the reading is 0x03FC instead of 0x03FF as would be expected. It very consistently gives 0x03FC. Is there something wrong in the code? Any adeas why this is happening?
//test
#include <16f819.h>
#device *=16 ADC=10
#use delay(clock=20000000)
#zero_ram
#case
//define these as necessary for particular circuit
#define ToPC            PIN_B2
#define FromPC            PIN_B3
#define LEDStatus              PIN_B4
// Function Prototypes
void testLEDS(void);
   int16 int16Temp, atodValue;
   int8 i;
    output_high(LEDStatus);  //off
   #use rs232(BAUD=19200, INVERT, XMIT=ToPC, RCV=FromPC)
   setup_port_a(RA0_ANALOG);
   set_adc_channel(0);
   printf("Running...\r\n");
      output_low(LEDStatus);     //on
        delay_ms(20);
      int16Temp = 0;
      for(i=0;i<10;i++)
         atodValue = read_adc();
         int16Temp = int16Temp + atodValue;
         printf("atodValue = %LX\r\n", atodValue);
      atodValue = 0;
      atodValue = int16Temp / (long)10;
      printf("atodValue AVG= %LX\r\n", atodValue);
    } //end while(1)
}  //end main
PostPosted: Mon Feb 09, 2004 11:37 am     Reply with quote
I think in these circumstances, I'd look at the generated assembler. The result is what you would see on the chips with an 8bit converter, if you specify a 10bit result, where the compiler will 'left justify' the 8bit result. The suspicion is that the compiler for some reason is doing this. The device editor does correctly list the part as having a 10bit AD (there are a number of errors in some parts, which need the device editor to fix, or some bodging round).
Try a 'bodge', like:
#byte ADRESH=0x1E
#byte ADRESL=0x9E
#bit ADGO=0x1F.2
read_adc(ADC_START_ONLY);
while (ADGO) ;
result=make16(ADRESH,ADRESL);
If 'result', contains the right value, then the problem is a fault with the compiler not handling the 10bit ADC on the 81x correctly, and you should moad to CCS.
Bill T
PostPosted: Mon Feb 09, 2004 10:35 pm     Reply with quote
If I understand correctly, the result is off by 3 ADC counts, out of the 2^10 or so possible. Gimme a break! There is nothing wrong. The power for the PIC isn't perfectly clean to be sure, and isn't a good ADC reference. And ADCs aren't perfect either, especially at the extremes. Get a good clean reference, inject a signal from a function generator, and check it out.
The PIC part does lots of stuff besides ADC - and look at the price. I would imagine the ADC performance has been traded off for other goodies. That's why they sell ADCs, and that's why they can get very expensive.....
SteveS
ADC accuracy
PostPosted: Tue Feb 10, 2004 7:41 am     Reply with quote
Actually the ADC in the PIC is very good. One of the electronics trade magazines did a test on the PIC 10 bit ADC a couple years ago and they were surprised at how well it performed. I tried to find the article just now but can't locate it.....
Anyway, besides the suggestions by others, read the reference manual section on the ADC. Timing, choice of clock, input impedance all play a role. The most accurate conversion technique uses the R/C ADC clock with the micro put to sleep during conversion.
I would also filter the ADC input; keeping in mind restrictions on input impedance.
- SteveS
Neutone
PostPosted: Tue Feb 10, 2004 8:37 am     Reply with quote
Its a new chip I think. I would not be supprised to find that the compiler is truncating the last two bits because the headder file has a bug.
Freddie
Re: 0x03FC instead of 0x03FF
PostPosted: Tue Feb 10, 2004 3:33 pm     Reply with quote
I've tried several PICS and crystals. I'm going to send a note to CCS.
