I am using a 18f8720 which has 2 rs 232 ports. These 2 ports I woul dlike to run at 2 diff speeds. The problem I am having is that when I try to switch the baud rates it does not work. When I have 2 #use statements in my code it always uses the last one. Please help.. TTY
curt2go
Posted: Thu Feb 05, 2004 1:07 pm
Found somthing in my second serch.. The stream = in the use rs232..
