const
Marcus
const
PostPosted: Tue Feb 03, 2004 9:06 am     Reply with quote
What const does when it was before a variable?
I tried it and does weird things.
thank you
Marcus
Felix Althaus
PostPosted: Tue Feb 03, 2004 9:10 am     Reply with quote
Hi
The qualifier const tells the compiler, that this 'variable' mustn't be changed so e.g. this is not allowed:
const int var;
var = 4; // not allowed because var is declared as const
What do you mean with "weird things"?
mfg
Felix
Marcus
const
PostPosted: Tue Feb 03, 2004 9:13 am     Reply with quote
this is suppose to function the same way that a regular variable? When i put const, my var doesn't do the right things.
Marcus
Re: const
PostPosted: Tue Feb 03, 2004 9:29 am     Reply with quote
it print 2 times the char in my var char[38][2] on the lcd and when i dont put const it work correctly
