Printf a negative float number
Guest_X44
PostPosted: Mon Feb 02, 2004 11:25 pm     Reply with quote
I can't get to send the correct value to the terminal. I'm expecting a value of -25.0625. This is based on the value from a DS1631 of 0xE6F0. Instead, I'm getting a value of 24.9999. Debugging it seems to indicate that this value does not include the fractional part. The other problem is how I can get to print a negative without resorting to concatenating the value with a negative symbol.
I can't also get the fractional part to be output.
I've used a constant value of 0xE6F0 for demonstration. Also, the code has been expanded just to make it clear to me whilst debugging so I can see what happens to each register when stepping through.
What have I done wrong?
#include <16f877.h>
#device ICD=TRUE
#fuses HS, NOLVP, NOWDT, PUT
#use delay(clock=20000000)
#use rs232(DEBUGGER)
signed long test_temp()
int datal, datah, x, y;
signed long data = 0;
float z = 0.00;
datah=0xE6;
datal=0xF0;
//process the two's complement...it's a negative
data = datah;
data = (data<<8) | datal;
data = ~data;
data += 1;
//get the whole portion
x = data>>12;
x *= 16;
y = data>>8 & 0b00001111;
//get the fractional part
z = (float)(data>>4 & 0b000000001111);
z /= 16.;
//get the result
data = x + y + z;
return(data);
main()
signed long value;
do{
value = test_temp();
printf("%f\r\n", (float)value);
}while(1);
Charlie U
PostPosted: Tue Feb 03, 2004 7:46 am     Reply with quote
By the time you are done with your function, you are returning a signed long int. This does not have a fractional part.
I haven't had a chance to verify this, but my first thought is that you loose your sign when you shift a signed number. As a test of the printf function, couldn't you first divide your signed long data by 16, which should preserve the sign:
data = data/16;
then cast the result to a float and multiply by 0.0625 and print the result?
return ((float)data*0.0625);
This would require returning a float from your function, but it would allow you to verify the printf question.
