Derek Prost Guest
| small 2 button enclosure |
Posted: Fri Jan 30, 2004 12:55 am |
I have developed a device using a PIC mounted on a small PC
board measuring approx. 2" x 2.5". It requires 2 switches to operate.
Can someone direct me to a vendor that sells small enclosures with
switches mounted on the enclosure? Thank you. |
MikeW
Joined: 15 Sep 2003 Posts: 185 Location: Warrington UK
Posted: Fri Jan 30, 2004 1:57 am |
it is normal to select the enclosure, then design the PCB around it.
However, try www.farnell.com
Mike |
SteveS
Posted: Fri Jan 30, 2004 8:39 am |
Look at Digi-Key or Mouser as they distribute a variety of enclosures. I saw one in Mouser that has buttons , but it's 2.23 x 1.29 - pretty cool though - a key fob type case. Surprisingly, Bud makes it (HH-3492). I always associate them with big metal racks, etc.
As an alternative look at Serpac, Hammond, or PacTec. They make a variety of nice plastic cases that you can easily machine to accomodate a board mounted switch.
Good luck. |
