Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Printf on UART2 |
Posted: Thu Jan 29, 2004 2:57 pm |
Hi.
I am using a PIC6720 with 2 hardware uarts. My question is how do I send data on UART2, as it defaults to UART1
I looked through the manual and could not find any reference to how to deal with the two different uarts, other than for receiving, which I don't have a problem with.
thanks in advance
Kasper
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use rs232(baud=38400,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8)
dyeatman
Using Two UARTS |
Posted: Thu Jan 29, 2004 3:19 pm |
You need to use the Stream= parameter with USE_RS232 then designate the Stream name within the serial command (FGETC, PUTC, sprintf etc).
See the manual page 59 for more info on the Stream= parameter then search this site for the word Stream and you will find a lot of examples...I have included an abbreviated example below.
#use rs232(baud=9600,xmit=PIN_C6,
rcv=PIN_C7,stream=PORT1,errors)
#use rs232(baud=4800,xmit=PIN_B1,
rcv=PIN_B0,stream=PORT2)
if (kbhit(PORT1))
BUFFER_1[i1] = fgetc(PORT1);
i1++;
if (kbhit(PORT2))
BUFFER_2[i2] = fgetc(PORT2);
i2++;
Neutone
Posted: Thu Jan 29, 2004 4:25 pm |
You should look throught the readme file. It has some information not available in the manual. Support for dual streams is newer than the manual and noted in the readme file. |
Kasper
Posted: Thu Jan 29, 2004 4:35 pm |
That works .. thanks alot  |
curt2go
Posted: Thu Feb 05, 2004 1:07 pm |
Where is the readme file. I am havin gthe same problem.. Thanx, |
curt2go
Posted: Thu Feb 05, 2004 1:16 pm |
Found it.. DUH!... TTY |
