Decimal number to individual chars
saholt
PostPosted: Tue Jan 27, 2004 6:21 pm     Reply with quote
Help, does anyone know how to take a decimal value eg. 1234 and convert this to 4 individual characters eg 1 2 3 4. Any help greatfully appreciated.
dyeatman
Convert 1234
PostPosted: Tue Jan 27, 2004 6:38 pm     Reply with quote
The easy way is to use the sprintf() function
dave
Use the sprintf() function to convert a 16-bit integer to an ASCII string.
After executing the following program, the contents of the buffer[]
array will be:
buffer[0] = '1'
buffer[1] = '2'
buffer[2] = '3'
buffer[3] = '4'
buffer[4] = 0
The use of single quotes around a number means it's an ASCII value.
The final 0 in buffer location 4, is the string terminator. It is not ASCII.
main()
char buffer[6]; // Allow enough room for 5 digits, plus the string terminator.
int16 value;
value = 1234;
sprintf(buffer, "%lu", value);
rrb011270
View user's profile Send private message Yahoo Messenger
PostPosted: Tue Jan 27, 2004 7:06 pm     Reply with quote
Mabuhay!
I hope this code snippet is of great help to you. This is based on the ASCII table of characters with their equivalent hex value.
// convert ascii number string to integer number
unsigned int8 asciiNum2Int(unsigned int8 index)
   unsigned int8 n;
   n = rxbuffer[index];
   if ((n<='9')&&(n>='0'))
      return (n&0x0F);     // Pure number 0 to 9
   if ((n<='F')&&(n>='A'))
      return ((n&0x0F)+9); // Hex nnumber A to F
   if ((n<='f')&&(n>='a'))
      return ((n&0x0F)+9); // Hex in lower case
   return (0);
unsigned int8 ascii2int8(unsigned int8 indx)  // convert ascii to interger
   unsigned int8 cnvt=0;
   //unsigned int8 indx=6;   // start index for command code
   cnvt = (asciiNum2Int(indx)*10) + asciiNum2Int(indx+1);
   return(cnvt);
   // convert ascii hex to long integer
unsigned int16 asciiHex2int16(unsigned int8 indx)
   unsigned int16 addr=0;        // address in word 0000 - FFFF
   //unsigned int8  indx=2;        // start index for MAC address retreival
   addr = ((asciiNum2Int(indx))*4096) + ((asciiNum2Int(indx+1))*256) +
          (asciiNum2Int(indx+2)*16) + asciiNum2Int(indx+3);
   return(addr);
enjoy and share your snippet....
