array size using PIC18F6720
Birdie
PostPosted: Wed Jan 21, 2004 10:22 am     Reply with quote
Using PIC18F6720 and PCWH 3.180
I have looked and cannot find any information that says I may not use a large array in my code, such as:
int MyArray[2048];
But I am experiencing problems, and if anyone knows of a problem with large arrays, please let me know.
Thanks in advance,
Birdie
Neutone
Re: array size using PIC18F6720
PostPosted: Wed Jan 21, 2004 10:54 am     Reply with quote
int MyArray[2048];
Thanks in advance,
Birdie
Thats a large array. You should locate the array at the beginning of a bank. The only time an array should cross a bank boundry is when it is larger than a single bank. Whenever posiable they should be located at the start of a bank.
int MyArray[2048];
#locate MyArray = 0x100     //Through 0x8FF
The process of indirect addressing will be greatly helped by not having to perform checks to see what bank is being accessed.
