Trouble while using port F as ADC (18F6720)
wedilo
PostPosted: Mon Jan 19, 2004 4:03 am     Reply with quote
I'm using a PIC 18F6720 with CCS-Compiler V 3.184.
Has anyone experience in using port F as ADC?
I tried this:
setup_adc_ports(ANALOG_AN0_TO_AN7)
In the header file of the 6720 I find:
#define ANALOG_AN0_TO_AN7 0x07 // A0 A1 A2 A3 A5 F0 F1 F2
The first five pins working correctly, but F0, F1 and F2 are not working.
Is here anyone who know why?
73 Sven
Mark
PostPosted: Mon Jan 19, 2004 6:59 am     Reply with quote
Did you make those pins inputs?
wedilo
PostPosted: Tue Jan 20, 2004 6:38 am     Reply with quote
Hello Mark,
Thanks for your reply.
Sorry, but I can't understand your message.
Did you mean that I maybe use port F for i/o operations?
If yes then I can say 'No, I don't'
Please have a look to the code:
Sorry, this is code by a friend of mine and only a snippet of the complete project.
set_tris_F(0xff);
Measure();
void Measure() {
   int ni,nm;
   long int res1;
   for (ni=0;ni<=7;ni++) {
      res1=0;
      SET_ADC_CHANNEL(ni);
      delay_ms(10);
      for (nm=1;nm<=5;nm++) {
         U[ni] = READ_ADC();
         res1 +=U[ni];
      U[ni]=((float)res1 / 5);
      printf("U Channel %U = %U\r\n",ni,U[ni]);
Yes, that's it. I copied it from the complete code and hope I havn't forgotten something.
The Channels 0...4 are still working, only 5...7 not.
73 Sven
