12F675 Sleep problem.. Standby current 80uA??
LuisF
PostPosted: Fri Jan 16, 2004 10:27 pm     Reply with quote
Hi All!
I have tried to sleep to the PIC12F675, because my application needs it
but the current is 80uA and not 1nA like it says the data sheet.
This is the program that i use.
Where is the error?
That I forget to turn off?
Thanks for any help.
#include <12F675.h>
#device adc=8
#fuses INTRC_IO,NOWDT,NOPUT,NOBROWNOUT,NOPROTECT,NOMCLR,NOCPD
setup_adc_ports(0);
setup_adc(ADC_OFF);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
OUTPUT_HIGH(PIN_A0);
DELAY_MS(500);
OUTPUT_LOW(PIN_A0);
WHILE(TRUE){
SLEEP();
For PIC 16F628 and PIC16F84 working fine and these are the programs.
#include <16F628.h>
#fuses INTRC_IO, NOPROTECT,NOWDT,NOPUT,NOLVP,NOBROWNOUT,NOPROTECT,NOMCLR,NOCPD
setup_vref(FALSE);
OUTPUT_HIGH(PIN_A1);
DELAY_MS(1000);
OUTPUT_LOW(PIN_A1);
WHILE(TRUE){
SLEEP();
#include <16F84A.h>
#fuses XT,NOWDT,NOPROTECT
output_high(pin_A1);
output_low(pin_A1);
while(True){
sleep();
} Question
Re: 12F675 Sleep problem.. Standby current 80uA??
PostPosted: Sat Jan 17, 2004 3:49 am     Reply with quote
LuisF wrote:
Hi All!
Where is the error?
#include <12F675.h>
#device adc=8
setup_adc_ports(0);
setup_adc(ADC_OFF);
setup_vref(FALSE);
DELAY_MS(500);
OUTPUT_LOW(PIN_A0);
WHILE(TRUE){
SLEEP();
#include <16F628.h>
setup_vref(FALSE);
DELAY_MS(1000);
OUTPUT_LOW(PIN_A1);
WHILE(TRUE){
SLEEP();
#include <16F84A.h>
output_low(pin_A1);
while(True){
sleep();
} Question
It may be nothing to do with the program. To get low standby currents, you have to look at everything 'else' round the chip. For instance, how are the signals 'held' when asleep, what is the consumption of your voltage regulator circuit, what do other chips in the circuit do, when their inputs float, etc. etc..
PostPosted: Sat Jan 17, 2004 7:13 am     Reply with quote
Ttelmah wrote:
LuisF wrote:
Hi All!
Where is the error?
#include <12F675.h>
#device adc=8
setup_adc_ports(0);
setup_adc(ADC_OFF);
setup_vref(FALSE);
DELAY_MS(500);
OUTPUT_LOW(PIN_A0);
WHILE(TRUE){
SLEEP();
#include <16F628.h>
setup_vref(FALSE);
DELAY_MS(1000);
OUTPUT_LOW(PIN_A1);
WHILE(TRUE){
SLEEP();
#include <16F84A.h>
output_low(pin_A1);
while(True){
sleep();
} Question
Thank for the help, but there is not anything connected to the PIC, only
a led to pin 7 with 1K resistor, I remove it and it is the same thing. I just test the standby current for evalution and I make it to decide which PIC to use. I measure the current in the pin 8 (Vdd=5 Volt)
If your you have time, make the test and you comment me your results.
Thanks for your time. Smile
Felix Althaus
PostPosted: Sat Jan 17, 2004 10:29 am     Reply with quote
Hi
I see two possible points for current reduction:
1) why do you use RTCC_INTERNAL? Use EXTERNAL and pull the T0CK pin low, so you don't have any changes in the tmr0 register
2) as default, all pins are inputs and there can be any voltage on open pins, causing them to draw "very much" current. Try to set all pins as outputs and set them low.
Perhaps this helps...
mfg
Felix
