ivarboer
| Fault in CCS compiler version 3.136, HELP ME!!!! |
Posted: Wed Jan 14, 2004 6:35 am |
Dear programmers,
Iam using a PIC16F877A processor in combination with CCS compiler version 3.316.
One of the code i use is the code below:
while ((Fl24HourRst) && (!FlWrtLastErrEep) && (!FlRunHigh1h) && (!FlRunLow1h) && (!FlBurnStrt));
Description:
Fl24HourRst = bit 7 of a byte (placed in bank 1 by the compiler)
FlWrtLastErrEep = bit 5 of a byte (placed in bank 0 by the compiler)
FlRunHigh1h = bit 0 of a byte (placed in bank 2 by the compiler)
FlRunLow1h = bit 1 of a byte (placed in bank 2 by the compiler)
FlBurnStrt = byte ((placed in bank 2 by the compiler)
Normally when Fl24HourRst = 1, FlWrtLastErrEep = 0, FlRunHigh1h = 0, FlRunLow1h = 0 and FlBurnStrt = 0 the programm has to stay inside the loop, but my programm doesn't.
I have checked the assemblycode and now i discovered that the compiler is not seting the right bank when jumping from the end of the while loop to the beginning of the while loop.
What is happening?
Isn't my code right?
Are there to many conditions in the while function?
Does the compiler contain errors?
Etc...
Iam using #device *=16
Please help me as soon as possible, because my EEPROM is overwritten sometimes.
Thanks!
Ivar |
neil
| An idea |
Posted: Wed Jan 14, 2004 10:17 am |
Hi Ivar, there are rather a lot of conditions in that one expression, might be a case of function overloading but I think it will handle them. Clearly if the compiler is putting the flags in different banks, it makes for more instruction cycles because of all the bank switching.
Try putting your flags into a struct of bit variables, I think this will make the compiler assign the bits sequentially to one byte so no bank switching is necessary between parts in the expression. However, if you are doing this, it might be easier to apply a mask for the condition you are looking for, instead of bit testing each flag individually. apply to the whole byte and exor it. You may need to mask out the 'don't cares' with an AND mask.
eg.
struct flags{
boolean Fl24HourRst, FlWrtLastErrEep, FlRunHigh1h, FlRunLow1h, FlBurnStrt;
int unused:3;
} flag_byte;
Now, for the logic states in your expression apply a mask of: xxx10000. So to test the state:
do "flag_byte &= 0b00011111;
if((flag_byte ^ 0b00010000)==0){ do stuff }"
This will be true when the structure of flags matches your test mask. I think this will be more efficient code, but not as easily readable.
Posted: Wed Jan 14, 2004 12:51 pm |
If he uses the structure, he can also write the test like this,
and keep his existing readability.
| Code: | while ((flag_byte.Fl24HourRst) &&
(!flag_byte.FlWrtLastErrEep) &&
(!flag_byte.FlRunHigh1h) &&
(!flag_byte.FlRunLow1h) &&
(!flag_byte.FlBurnStrt)); |
This will produce ASM code like this:
| Code: | 0014 1C21 BTFSS 21.0
0015 281E GOTO 01E
0016 18A1 BTFSC 21.1
0017 281E GOTO 01E
0018 1921 BTFSC 21.2
0019 281E GOTO 01E
001A 19A1 BTFSC 21.3
001B 281E GOTO 01E
001C 1E21 BTFSS 21.4
001D 2814 GOTO 014 |
Ivar Boer Guest
| Fault in CCS compiler version |
Posted: Thu Jan 15, 2004 3:01 am |
Thanks for your information, but this information does not help me to determine the reason of my problem. Maybe the complier has made more wrong code which i don't know.
Could it be a compiler error????
Thanks.
Ivar |
SherpaDoug
Posted: Thu Jan 15, 2004 8:45 am |
A compiler error is certainly a possibility. They are common in any uC compiler. But my first step would be to break that long line into smaller more digestable pieces. Then look at the assembler and see just what the compiler is doing. Then you will be able to find a way to get the behavior you want. The procedure is the same whether it is a compiler error or more likely a programmer error. _________________ The search for better is endless. Instead simply find very good and get the job done. |
