Pointer Address
arga
Pointer Address
PostPosted: Tue Jan 13, 2004 9:47 pm     Reply with quote
How do you ABSOLUTELY make sure that the pointer holds the correct address if it is pointing to an array.
Sample of this code below presents a problem with addressing. The pointers seems to be confused even though the pointer is initialised by calling it inside main().
Assume that the array aX is allocated in BOTH Bank 1 and Bank 2. Therefore, the address is 14 bits wide but i seems the pointer SOMETIMES only copies the first 8 bits.
//declarations
int aX[60];
int *pA;
void initPointer()
pA = aX;
main()
initPointer();
//more code here to handle timer, processing of ata in aX, so, so...
Any help? Or should I just AVOID using pointers at all times.
PostPosted: Wed Jan 14, 2004 1:20 am     Reply with quote
Is this a theoretical problem, or is this a problem that you have
definitely found ?
What PIC are you using ?
What is the version of the compiler ?
Because you mentioned a 14-bit address, I'll assume that you
are using the PCM compiler. I'll assume the PIC is a 16F877.
The compiler will never do this. Each array must not exceed
the size of a RAM bank.
int aX[60];
Remember that in CCS, an "int" is only 8-bits. Therefore, this
array only uses 60 bytes. Since a RAM bank on a 16F877 is at least
80 bytes, the array will fit within one RAM bank. If it doesn't fit, the
compiler will give you an error messsage.
Therefore, the address is 14 bits wide but it seems the pointer SOMETIMES only copies the first 8 bits.
If the compiler is using 8-bit pointers, it will only copy the lower 8-bits.
To enable 16-bit pointers, you need to do this:
#include <16F877.H>
#device *=16    // This line enables 16-bit pointers
arga
PostPosted: Wed Jan 14, 2004 3:30 am     Reply with quote
The problem I have is that the array is in bank 1.
The array is type int, and so is the pointer.
#device *=16 is included.
I'm using the pic16f877, compiler ver. 3.173
PostPosted: Wed Jan 14, 2004 8:19 am     Reply with quote
I hope you mean that the pointer, is a pointer to an int, not an 'int' as such. Remember that an 'int', will only hold an 8bit value on a PIC, and an address (with 16bit RAM addressing), needs a 16bit storage location.
I have run into problems with the compiler truncating pointers in the past, but have not seen this on the more recent versions. When I ran into this, I found that I could 'bodeg' round the problem, by using a forced cast. I found that if you specifically tell the compiler to treat the pointers as being to 'long' types, it prevented the behaviour.
However this fault was definately fixed a long time ago.
Mark
PostPosted: Wed Jan 14, 2004 8:21 am     Reply with quote
So what is the problem? The upper byte shouldn't need to be changed if the array is in a bank. It would just be wasted instructions. Are you having a problem with the address being incorrect?
