sizeof() returns an erroneous value with structure !!!
franckcl
PostPosted: Tue Jan 13, 2004 5:37 am     Reply with quote
Here is a problem with PCHW v3.182 (and PIC18F6520)
here is the code :
typedef struct
BYTE Signature[3];
BYTE buffer[128];
}t_EE;
t_EE EE;
#define SizeSignature sizeof(EE.Signature)
==> the SizeSignature is 0x83 and not 3 !!!!!!!!!!
but if the structure size is lower than 128 bytes, there is no problem.
Is there a limitation of the size of a structure ???
Is someone have the same result ???
Thank you
Franck
PostPosted: Tue Jan 13, 2004 1:49 pm     Reply with quote
That bug was reported here, on March 18, 2003.
http://www.ccsinfo.com/forum/viewtopic.php?t=3003
Also here, on Sept. 17, 2002
http://www.ccsinfo.com/forum/viewtopic.php?t=13886
Maybe if it gets reported one more time, it will get fixed ?
Rolling Eyes
Those complaints were about PCM, not PCH.
I did a test on vs. PCM vs. 3.183, to see how it's doing.
Not good. The following sample program displayed this result:
Size of Signature = 83
It should be 3.
#include "16F877.h"
#use delay(clock = 8000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
typedef struct
BYTE Signature[3];
BYTE buffer[80]; // Use a smaller buffer size, for 16F877
}t_EE;
t_EE EE;
main()
char c;
c = SizeSignature;
printf("Size of Signature = %u ", c);
