PIC18F452, ICD=TRUE and HS Oscillator?
grunwald
PostPosted: Mon Jan 12, 2004 10:54 am     Reply with quote
I use PCWH 3.183 to compile for a PIC18F452. I want to debug my hardware
with the ICD-U40.
If I use the directive "#device ICD=TRUE" then all my
"#fuses" settings are ignored. Because I use a 20MHz crystal
I have to enable "HS" Oscillator, but PCWH ignores all
the parameters and sets an "RC_IO" osc ...
What can I do to use my "HS" oscillator and to use set other fuse bits?
My setting look like this:
#include <18F452.h>
#device *=16 adc=10
#device ICD=TRUE
#fuses HS,NOPROTECT,NOOSCSEN,NOBROWNOUT,NOWDT,PUT,CCP2B3,NOSTVREN,DEBUG,NOLVP,NOWRT,NOWRTD,NOWRTB,NOWRTC,NOCPD,NOCPB,NOEBTR,NOEBTRB
#OPT 9
#use delay(clock=20000000) //20MHz Clock Speed
Thank You for Your support,
Bernd Grunwald
Neutone
PostPosted: Mon Jan 12, 2004 12:40 pm     Reply with quote
Go back to 3.182 this is the last part of the readme file on the download page. Look at what it says about ICD=TRUE
3.181 #ROM now allocates a dedicated segment, see README.TXT for more info
3.181 Improved optimization
3.181 Support for newest chips has been added (including the 648A debugger)
3.182 Updates for the newest chips
3.183 The #INT_RB was changed to #INT_RA on parts with no port B
3.183 A bug with the ++ operator on field pointers in *=16 mode is fixed
3.183 A PIC18 problem with floating point - when a float crosses a bank is fixed
3.183 The fuse settings forced in ICD=TRUE mode have changed for some parts
3.183 The LABEL_ADDRESS function now may be used to obtain the address of CONST data
