Compatibility problem with const string on several lines
franckcl
PostPosted: Thu Jan 08, 2004 5:37 am     Reply with quote
CCS add a space character and the LF (0x0A) character at the end of each following lines :
const char MyString[]={"\
First,\
Second,\
Third"};
After compilation the string becomes :
\x20\x0AFirst,\x20\x0ASecond,\x20\x0AThird
I think that is not ansi compatible.
I have compile it with Borland C compiler and the result is :
First,Second,Third
Is there a solution to remove the 0x20 and 0x0A characters ?
This is a real problem for me !
Thank you
Franck
Re: Compatibility problem with const string on several lines
PostPosted: Thu Jan 08, 2004 6:20 am     Reply with quote
franckcl wrote:
First,\
Second,\
Third"};
First,Second,Third
Thank you
Franck
You will get the result you want with:
const char MyString[]={\
"First,"\
"Second,"\
"Third"};
franckcl
PostPosted: Thu Jan 08, 2004 7:20 am     Reply with quote
YES..... Good it is Ok now,
Thank you very much for your help "Ttelmah" !!
Franck
