Haplo
| Strange...This might be useful information for you all |
Posted: Tue Jan 06, 2004 10:30 pm |
After wasting two days on a stupid problem, I discovered something today. Most of you may know it already but for those of you who don't (I didn't) it can save a lot of time & hassle. In an application I'm using PCM 3.181, PIC16F870 with a software I2C port (C4 & C5). I had set C0 and C1 to outputs. The problem is everytime an I2C function was called, C0 and C1 were set back to inputs (bits 0 and 1 of TRISC got set). After two frustrating days I found the reason:
When I use this method to set TRISC:
#byte TRISC=0x87
TRISC = 0b11111100;
I get this in the list file:
.................... TRISC = 0b11111100;
0067: MOVLW FC
0068: MOVWF 07 |
But when I use set_tris_c(0b11111100); I get this:
.................... set_tris_c(0b11111100);
0067: MOVLW FC
0068: MOVWF 07
0069: BCF 03.5
006A: MOVWF 2E |
It seems the compiler uses the address 2E to hold a second copy of the value of TRISC. Then in the I2C routines that value is used to change the configuration of the SDA pin. Forexample:
.................... #use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
00E4: MOVLW 08
00E5: MOVWF 21
00E6: NOP
00E7: NOP
00E8: BCF 07.3
00E9: BCF 2E.3
00EA: MOVF 2E,W
00EB: BSF 03.5
00EC: MOVWF 07
00ED: NOP
And in the Symbol Map file I have these two lines:
02E @TRIS_C
087 TRISC
Well it seems setting TRISC directly is not always a good idea.
And there other strange thing...This only happens for TRISC. When I changed my #USE I2C to use B4 and B5 instead, the compiler didn't do the same thing for TRISB, but still did it for TRSIC. And the I2C routine looked like this:
.................... #use i2c(Master,Fast,sda=PIN_B4,scl=PIN_B3)
00E4: MOVLW 08
00E5: MOVWF 21
00E6: NOP
00E7: NOP
00E8: BCF 06.3
00E9: BSF 03.5
00EA: BCF 06.3
00EB: NOP
As you can see TRISB got modified directly, unlike when I used pins C4 and C5 where the address 2E is also used.
Using both standard_io and fast_io yield to the same results.
Does anyone know why the compiler acts like that?? |
burnsy
Joined: 18 Oct 2003 Posts: 35 Location: Brisbane, Australia
| got me too! |
Posted: Wed Jan 07, 2004 1:11 am |
Yep that one always comes back to bite you on the backside. It got me in the last 24 hours as well. grrrr _________________ This is the last code change until its ready.... |
