MMC Endurance?
Niewbie
MMC Endurance?
PostPosted: Sun Jan 04, 2004 8:25 am     Reply with quote
What is the maximum write cycles for MMC, can't find anything on this as all I get is people advertising cards!
P.S. What IC technology is in the MMC if you know that I might be able to find the answer myself.
Newbie
More questions!!
PostPosted: Sun Jan 04, 2004 9:04 am     Reply with quote
I'm still trying to find answeres on this, and thought of answer question, I think I have found the MMC has 300,000 write/erase cycles, CF about 1,000,000 but does that apply to the entire device or each byte?
In other words is I write 1 byte to address 0,1,2,3,4,5,6 etc in a CF and I get to address 1,000,0000 it will stop or if I write 1 byte to address 0 1,000,000 times then address 0 will fail?
johnh
PostPosted: Sun Jan 04, 2004 9:12 am     Reply with quote
Hi
Follow this link, i haven't read it all but there should be some answers in there.
http://www.mmca.org/tech/MMC-System-Summary-v3.31.pdf
Also try searching google for MultiMediaCard write cycles
I just tried it and it comes up with some info.
John
There are 10 kinds of people who understand binary, those who do and those who don't
steve_st23
PostPosted: Sun Jan 11, 2004 7:51 am     Reply with quote
follow this link for sd card and look at page 11 section 1.5.4 Endurance http://www.sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf
100000 write cycle for each sector typical (from 512 bytes to maximum capacity for each sector)
