malloc() and free()
pm
malloc() and free()
PostPosted: Mon Dec 29, 2003 12:04 pm     Reply with quote
WHen using repeated calls to malloc() and free() the code will hang up.
example:
int *ptr;
main()
ptr=malloc(10);
void subroutine()
if(ptr) free(ptr);
ptr=malloc(10);
after calling subroutine once or twice it hangs. Any ideas why?
PostPosted: Mon Dec 29, 2003 1:42 pm     Reply with quote
Can you give the version of compiler that you're using,
and also the PIC ?
pm
response to free() and malloc()
PostPosted: Mon Dec 29, 2003 3:44 pm     Reply with quote
im using a pic16f877a and the compiler is pcm version 3.169
thanks
PostPosted: Mon Dec 29, 2003 4:11 pm     Reply with quote
The program that you posted doesn't do what you
explain in your text. ie., it doesn't call subroutine().
Can you copy and paste a demo program from your
MPLAB project into a post here, so I can see the exact
program that fails ? (ie., a short demo program that
shows the problem). Then I can test it with PCM
vs. 3.169 as well as the latest version.
pm
PostPosted: Wed Dec 31, 2003 1:02 pm     Reply with quote
I re-worked the code to overcome this problem. I only allocate the space once and this seems to work. I was trying to use the same pointer to point to different strings based on certain conditions. I still do the same thing but include the length of the strings in the parameter list passed to the subsequent function. But now my curiosity is piqued. Why would it fail? The code sure looks valid. I'd rather not post any code fragments at this time. What is your opinion of doing repeated calls to malloc() and free() i.e. using the same pointer over and over. I have done this before in C, but never on a microcontroller. Never had a problem in the past.
Thanks for your help
pat
PostPosted: Wed Dec 31, 2003 1:32 pm     Reply with quote
I can't work on the problem accurately without a demo that
shows the problem. Someone else will have to help you.
dyeatman
Malloc()
PostPosted: Wed Dec 31, 2003 2:09 pm     Reply with quote
Besides, if it is that secret I would be afraid that Tom Ridge would show up at my door after I read it... Laughing
