| PCM programmer
				|  Posted: Mon Dec 29, 2003 1:28 pm |   |
				|  	  | Quote: |  	  | One is to move the GLCD Data Port to PORTB. |
 I assume you're using the CCS driver file, GLCD.C.
 If you look closely at the code in that file, you will see several
 lines where it calls the input_d() and output_d() functions.
 Example:
  	  | Code: |  	  | output_d(data);            // Put the data on the port |
 To change the driver to use Port B, you need to change those
 lines to input_b() and output_b().   Make sure that you find
 every line of code that needs to be changed.  (Of course, this
 assumes that you have moved all the control signals to a
 different port, since the GLCD.C driver originally had them on
 Port B).
