		| Author | Message |
		| Kari Guest
				| Defining Timer0 to 8bit on 18F452 |
				|  Posted: Mon Dec 29, 2003 4:25 am |   |
				| Even if I define Timer0 to 8bit, "setup_timer_0(RTCC_EXT_H_TO_L|RTCC_8_BIT);"
 "printf(lcd_putc,"%03u",get_rtcc());" is not working. Compiler says "print format type is invalid". GET_RTCC() returns still long int because "printf(lcd_putc,"%03lu",get_rtcc());" is working. Is there something else to remember to  define RTCC to 8bit?
 PCWH is 3.180
 Regards Kari, Finland
		| Ttelmah Guest
				| Re: Defining Timer0 to 8bit on 18F452 |
				|  Posted: Mon Dec 29, 2003 5:25 am |   |
				|  	  | Kari wrote: |  	  | Even if I define Timer0 to 8bit, "setup_timer_0(RTCC_EXT_H_TO_L|RTCC_8_BIT);"
 PCWH is 3.180
 'u', only supports an integer (8 bit). You have told the compiler to return a 16bit value for 'get_rtcc'. You need to use 'lu'.
		| Kari Guest
				|  Posted: Mon Dec 29, 2003 5:58 am |   |
				| I have defined timer0 to work in 8-bit mode  with this line: setup_timer_0(RTCC_EXT_H_TO_L|RTCC_8_BIT);
 Register value from asm listing is correct (0xF0).
 Kari
		| Ttelmah Guest
				|  Posted: Mon Dec 29, 2003 7:20 am |   |
				|  	  | Kari wrote: |  	  | I have defined timer0 to work in 8-bit mode  with this line: setup_timer_0(RTCC_EXT_H_TO_L|RTCC_8_BIT);
 Kari
 You are operating the timer in 8bit 'mode', but the _function_, returns a 16bit value, because the timer supports this. Hence you either have to use a long declaration, or retrieve the low byte only.
 This would work:
 printf(lcd_putc,"%03u",(int8)get_rtcc());
		| Kari Guest
				|  Posted: Mon Dec 29, 2003 7:44 am |   |
				| Ok thanks, now I know it. I am moving from 16f877 to 18f452 and looking for easiest way to change code for it.
 kari
 | You cannot post new topics in this forum You cannot reply to topics in this forum
