I'm in the UK and looking for somewhere to get a pre-wired PCB header connector. 6-8 way and 2.0amp per pole. 200mm fly leads.
There must be a company out there that does off the shelf connectors or if you have seem similar sold as a replacment part then Please please point me to it.
I am in the design phase of the PCB so I can be felxible on type,But I don't want to sit there making these wires if I sell even 50 of these! and I don't want a bespoke assembly making by a company as I can imagine it will cost, just want a off the shelf job, cheap
http://www.heritagemedcall.com/HM-ECUP.htm
Your best bet might be to find a technician working for a local firm and see if he would be interested in a bit of "out of hours work, cash in hand". With luck he will have access to crimping tools etc.
If I've understood correctly these are packs of 10 wires with the crimp contacts fitted ready to be fitted into a housing. Check I've got that right before you buy. Not particularly cheap.
