		| Author | Message |
		| Vacio
				| How make a bounce free code? Help Please |
				|  Posted: Thu Dec 18, 2003 4:20 am |   |
				| How make a bounce free by software code in the CCP1 and CCP2 interruptions?
 here the code
  	  | Code: |  	  | int8 T;
 void Contador (void);
 #int_CCP1
 void CCP1_isr(void)
 T=0;
 #int_CCP2
 void CCP2_isr(void) {
 Contador();
 T=T+1;
 //output_B(T);
 setup_adc_ports(A_ANALOG);
 setup_spi(FALSE);
 setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
 setup_timer_1(T1_DISABLED);
 setup_ccp1(CCP_CAPTURE_FE);
 setup_ccp2(CCP_CAPTURE_FE);
 setup_vref(FALSE);
 enable_interrupts(INT_CCP1);
 enable_interrupts(INT_CCP2);
 //   enable_interrupts(INT_EXT);
 enable_interrupts(global);
 output_B(T);
 any idea?
  and the other question it's, how work the external interruption in the PIC16F84 in the CCS compiler, I did't work the code for me, help me please with my two newbie questions
 Thanks for you answers
		| PCM programmer
				|  Posted: Thu Dec 18, 2003 4:00 pm |   |
				| I'm not sure what your overall project is. You're trying to use CCP capture mode, but
 you have disabled Timer1.   So the capture
 mode will not work.  You should look at some
 CCS example files which show how to use the
 CCP capture mode.  These are:
 EX_REACT.C
 EX_CCPMP.C
 These files are in this folder:  c:\Program Files\Picc\Examples
 To answer your other question about using INT_EXT with
 the 16F84, you should study this example shown in this thread:
 http://www.ccsinfo.com/forum/viewtopic.php?t=17041
		| Vacio
				|  Posted: Mon Dec 22, 2003 9:03 am |   |
				|  	  | PCM programmer wrote: |  	  | I'm not sure what your overall project is. You're trying to use CCP capture mode, but
 EX_REACT.C
 EX_CCPMP.C
 Thanks Very Much PCM Programmer
 I will read the example, and I will back later to the forum
