tedlarson
| Bootloader (loader.c) troubles... |
Posted: Mon Dec 01, 2003 2:16 pm |
I used the CCS bootloader sample, loader.c to make a simple boot loader for a PIC18F252. It seems to work very well when working with a toy/example program.
I went and tried to retrofit an existing (large) program with it, and immediately ran into trouble.
real_load_program
Seg 7C0A-7FFE, 033E left, need 0340
Seg 0000-0002, 0000 left, need 0340
Seg 0004-0006, 0004 left, need 0340
Seg 0008-00A2, 0000 left, need 0340
load_program
When I remove the "load.c" from my include list, I have 50% of my ROM free on the device, so I suspect that an individual segment is overflowing. I have gone through and used the #segment directive on all my functions, but it still doesn't seem to break things up enough. Does anyone have any suggestions on things I can do to get around the problem?
Thanks,
- Ted |
Mark
Posted: Mon Dec 01, 2003 3:04 pm |
| I hope you meant #separate. Look at the lst file and the functions and see which ones are really large. Take those and break them up into smaller functions. |
tedlarson
Posted: Mon Dec 01, 2003 5:00 pm |
Whew!
After lots of looking at the list file, and breaking things up more....still no luck. Then, I started commenting things out until it would compile.
I isolated the problem to the following.
I have two global arrays in the program:
long vlist[25];
int vstat[25];
I notice that when I reduce the array size to something small....I suddenly can compile. I have a feeling that the compiler is trying to shove these into the same segment as the loader and having trouble. How can I move these out to somewhere else in memory, so they won't get in the way?
Thanks,
-Ted |
Mark
Posted: Mon Dec 01, 2003 6:57 pm |
| Those are ram based and the problem you are having is rom shortage. sometimes moving variables around reduces the code size due to the bank switching instructions. |
tedlarson
Posted: Tue Dec 02, 2003 11:59 am |
| Mark wrote: | | Those are ram based and the problem you are having is rom shortage. sometimes moving variables around reduces the code size due to the bank switching instructions. |
That is what I thought too. Although, I have noticed that I can reduce the total code size...so that the compiler will report to me that only 10% of the rom is being used. Then, I add-in the loader.c code, and I suddenly run out.
I have noticed that reducing the number of global variables I have affects it's ability to compile. Other than bank switching, is there something else about global variables that would cause an out-of-rom situation?
The behavior the compiler is giving me just doesn't make sense.
- Ted |
tedlarson
Posted: Tue Dec 09, 2003 8:36 pm |
Ok....CCS tech support replied with an answer to the problem. I thought I would post my results, so the next guy who has the same trouble will know what to do.
LOADER_SIZE is incorrect for the PCH compiler.
It is too small. Currently I am using 0x41F
and it seems to all work now....although that value was
obtained by trial and error.
The next problem I am having is, when using it on a PIC16F876, it sucks up 50% of the available ram. Sooo...I am stuck again, with a different problem now.
Anyone out there know the answer to this one?
Thanks,
- Ted |
Mark
Posted: Wed Dec 10, 2003 7:18 am |
Do you have
in your code? |
