StI2yICeR Guest
| PCW C Compiler IDE for 16F877 Microchip |
Posted: Tue Nov 11, 2003 9:10 pm |
Hello.
I am very frustrated - I have been trying to send text through the serial port using my 16F877 microchip using the following code.
I am using the PCW C Compiler IDE to compile / load my C program onto the chip.
#include <16F877.h>
#fuses nowdt, hs
#device ICD=true
void delay(void);
void pause(unsigned int count);
unsigned int i;
while (1) {
output_bit(PIN_B4, 0);
pause(4);
output_bit(PIN_B4, 1);
pause(4);
output_bit(PIN_C6, 0);
delay();
for (i=0; i<4; i++) {
output_bit(PIN_C6, 1);
delay();
delay();
delay();
void pause (unsigned int count){
unsigned long int i,j;
for(i=0;i<count;i++)
for (j=0;j<0xffff;j++);
void delay() {
setup_timer_0(RTCC_DIV_8);
set_timer0(0);
while (get_timer0() < 130);
Now the above setup assumes that the receiving end has baud 4800, parity = none, stop bits = 1, data bits = 8, flow control = none.
PIN_B4 is the LED pin (just for show) and PIN_C6 is the chip's output pin.
When the program is run, I get the following on my hyperterminal:
UUUUUUUUUWUUUUUUUUUUUUUUUUUUUUUUUUUUÕUUUUU]UUUUÕUUUUUUUUUUUUUUuUU]UUUUUUUUUUUUUÕÕUÕUUUÕUUuUWUUUUUUUUUUUWUÕUUUUUUÕUUUUUUUUUUUUUUWUUUUUUUUUUUUUUUUUUUUUUUUUUUUUuUUUUUUUUUUÕUUUUUUUWUUUUUUUUUUUUÕUUUUUUU
From the code, I should be getting all U's, as follows:
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
I am not using the printf function because that results in similar mistranscriptions - I wanted to get down to the nitty-gritty basics in order to understand the problem.
I am totally lost on this one. Thank you for your time and consideration. |
Posted: Tue Nov 11, 2003 10:02 pm |
You shouldn't do it that way. You should use the CCS RS-232 functions
and if you're doing a delay, use the CCS delay functions.
That's why we buy this compiler.
The key to making everything work is the #use Delay statement,
which tells the compiler your crystal frequency. From that value,
it will calculate the correct timing for everything. So if you're using
a 20 MHz crystal, then do it as shown in the example below.
If you're using the ICD, then put in the #device statement for that, too.
| Code: | #include <16F877.h>
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use Delay(clock=20000000)
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7, errors)
main()
putc('U');
This assumes that your PC (presumably running HyperTerminal) is
set for 4800, N, 8, 1. |
StI2yICeR Guest
| Still some anomalies... |
Posted: Wed Nov 12, 2003 9:25 am |
Hi. I am grateful for your help. The following is my code:
#device ICD=true
main()
putc('U');
Yet, I received the following on my HyperTerminal:
UUÕUUUUUUUUUUUUUÕUUUUUUUUUUUUUUUUUUUU]UUWUUUUUUUUUUUUUUUUUUUUÕUUUUUUUUUUUUUUUUUuUUUÕUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUÕWUUUUUUUUUUUÕ
What could be the cause of such mistransmissions?
I suppose I would have to resort to manual error checking (by using feedback to see if what was sent equals what was received) if this anomaly is an error in the chip itself. |
Mark
Posted: Wed Nov 12, 2003 1:07 pm |
| How are you connecting the PIC to the PC. Maybe the problem is there. |
Posted: Wed Nov 12, 2003 1:29 pm |
I tested my sample program with HyperTerminal on Win98,
at 4800,N,8,1 and it works fine. It displays hundreds of "UUU"
with no problems.
I'm using a MAX232A chip for the RS-232 level conversion.
As a test, I went into Device Manager and in the Advanced section
for Com Port 1, and turned off the receive fifo. It still worked OK.
So, I think the problem could be:
1. Your crystal. Is it really running at 20 MHz ?
Are you using a crystal, or something else (resonator ?).
2. As Mark says, how are you connecting it to your PC ?
Do you have a Ground wire, going from pin 5 on the DB-9
(on the PC side) to ground on your PIC board ?
Do you have a MAX232A (or equivalent chip), and is it
putting out proper RS-232 levels ? |
