C-H Wu Guest
| Bug_3.200 and 3.191 ... delay_us |
Posted: Sat May 22, 2004 6:58 am |
PCH 3.191 and 3.200 both failed under the following simple test !
delay_us() is broken ! !
>> 3.191 An accuracy problem in the delay functions is fixed
It is NOT fully tested !
#include <18F458.H>
#fuses HS, OSCSEN, NOWDT, BORV27, PUT, STVREN, NODEBUG, NOLVP
#use delay(clock= 20000000)
#use RS232(baud = 115200, xmit= PIN_C6, rcv= PIN_C7)
int16 i; int8 k= 0;
while ( 1 )
// for(i=0;i<10000;i++) delay_us(100); <-- this is ok
for(i=0;i< 5000;i++) delay_us(200); // <-- crashed in this case !
printf("%u ", ++k);
what can I say? throw out a new release on Friday, pick up beta test report on Monday morning ? it is not good, NOT at all. |
Hans Wedemeyer
| Re: Bug_3.200 and 3.191 ... delay_us |
Posted: Sat May 22, 2004 5:17 pm |
| C-H Wu wrote: | PCH 3.191 and 3.200 both failed under the following simple test !
#include <18F458.H>
int16 i; int8 k= 0;
while ( 1 )
printf("%u ", ++k);
I just copy/pasted your code and compiled it using Version 3.19 and it did not crash.
When you say "crashed in this line" I assume you mean the compiler crashed ! or did you mean the code on the PIC crashed ?
Best regards
Hans Wedemeyer |
C-H Wu Guest
| delay_us(200) delays less than 5 usec |
Posted: Sat May 22, 2004 8:48 pm |
Sorry for the term 'crashed', what happened is the numbers generated by printf("%u ", ++k) run so fast on the terminal instead of poping out once every second, it seems that delay_us(200) delays less than 5 usec !
delay_us(n) works fine for n < 154.
What really crashed is my delay_us() based simple beeper routine.
Best regards |
