Float into 4 int
AKA
Float into 4 int
PostPosted: Mon Oct 20, 2003 8:49 am     Reply with quote
Hi all.
do u guys have any idea on how to convert a float number (32bit)
into 4 int (8-bit) ?
i need it so i could convert my float number to send ove rto dallas one wire device. they recive one byte at a time... arghh.
pls help.. thank you.
Re: Float into 4 int
PostPosted: Mon Oct 20, 2003 9:07 am     Reply with quote
AKA wrote:
Hi all.
Been answered many time before.
Two 'different' methods. One is just to use a pointer, cast it to point to an int8, and read the bytes using this. However my favourite (and it gives more efficient code :-), is to use a union. So:
Union {
int8 b[4];
float flt;
} value;
Then 'value.flt', is the floating point number, and can be used as normal in your code, while 'value.b[0]', now refers to the first byte of the number, through to 'value.b[3]', holding the last byte.
So:
int count;
value.flt=1000.0;
for (count=0;count<4;count++) {
sendbyte(value.b[count]);
Will (assuming you have a suitable 'sendbyte' function, that expects to receive an int8), send the individual bytes in order. In the example given, sendbyte will be called first with '0x88', then with '0x7A', then with 0, and again with 0.
Conveniently, the same trick, can be used at the other end, to 'reassemble' the bytes to form the float (just put the bytes into 'value.b[n]', and when all the bytes are in place, 'value.flt', will contain the original number).
You can even 'cheat' with this, since the CCS compiler, does not restrict implied casting of numbers. So:
union FTOB {
int8 b[4];
float flt;
void sendfloat(union FTOB value) {
int count;
value.flt=1000.0;
Can be called as:
sendfloat(1000.0);
(or with a float variable), and will automatically be treated as the union inside the subroutine, allowing the bytes to be individually accessed.
AKA
PostPosted: Mon Oct 20, 2003 9:16 am     Reply with quote
geezs thanks will try that
AKA
stupid ques
PostPosted: Mon Oct 20, 2003 9:58 am     Reply with quote
yo .,, thanks for the code.
got it implemented but ccs compiler says" Expecting a structure/union"
is it is already defined, as in
union FTOB {
int8 b[4];
float flt;
thanks .. again
