cyberjack
| Reprogramming 12F629 OSCCAL after erase flash in mplab 6.x |
Posted: Sun Oct 05, 2003 2:12 pm |
Aplogies if this is slightly off topic, but I'm not sure if this is a CCS issue or an mplab 6.x issue.
I'm working with incircuit programming of a 12F629 and can successfully read/write/verify the chip. However, when I erase the flash, it erases all of program memory, including the OSCCAL value at 0x3ff. No worries, right?
I just use:
| Code: | | #rom 0x3FF={OSC_VALUE} |
and everything is happy...
Except here's the kicker, mplab 6.x refuses to program that address. When I check programming ranges, it shows me 0-0x3FE, and gives an error when I change to range to include 0x3FF.
Should I be using a different CCS option? Is this a bug in mplab 6? What am I missing?!?
Thanks a ton,
-Josh |
