Setting Up Internal Oscilator Block for PIC16F87
elcom
PostPosted: Mon Sep 15, 2003 7:18 am     Reply with quote
I would like to ask, if anybody know how to setup Internal Oscillator Block in the PIC16F87. Shall I have to use direct SFR programming, or it is possible to do using implemented “C” commands. I need to use internal clock 8 MHZ. In case of use direct SFR programming what is the best way to do it?
Thank you very much in advance,
Ioannis
john cutler
PostPosted: Mon Sep 15, 2003 9:26 am     Reply with quote
I found that the CCS header for the 16F88 was missing the internal osc settings. I wrote CCS and the person there replied saying that this would be corrected in the next compiler release. Meanwhile, I used assy SFR bit setting to accomplish this. Seems to work fine.
Download the data sheet pdf from Microchip's site. It's pretty self explanatory.
jc
elcom
PostPosted: Mon Sep 15, 2003 9:53 am     Reply with quote
Could you please send send me some line of your code just to see how you have done it.
thank you in advance
rgds
ioannis
john cutler
PostPosted: Mon Sep 15, 2003 1:04 pm     Reply with quote
Well, what I did was to set the CCS #fuses directive the way I wanted (except for oscillator)
#fuses HS, NOWDT, NOLVP, NOMCLR
then I compiled the code and looked at the .lst output file on the bottom at the configuration fuses. (The compiler added other options as well)
the configuration word was listed with a value of 3702
If you look at page 129 or the .pdf, you'll see a description of the config words - the address is 0x2007 which is above the normal memory. Your can access it with a #rom statement at the beginning of your code.
bits 4, 1 and 0 of config word 1 control oscillator selection.
for my purposes, I ended up with
#rom 0x2007 = {3711}
which gave me internal osc with clk ouput on pin A6
I hope this helps.
jc
elcom
PostPosted: Mon Sep 15, 2003 1:07 pm     Reply with quote
Thank you!
I'm going to impleent is right now.
regards
Ioannis
john cutler
PostPosted: Mon Sep 15, 2003 4:51 pm     Reply with quote
Well, I just checked and CCS posted a new version of the compiler 3.177 which insludes an udpataed header file for the 16F87/88. Now, INTRC and INTRC_IO are listed.
Try it out.
jc
elcom
PostPosted: Tue Sep 16, 2003 12:22 am     Reply with quote
I saw it also. But in any case I tested your solution, whitch is working.
Ioannis
troy
PostPosted: Tue Jan 27, 2004 12:54 pm     Reply with quote
#rom also works for disabling the Fail-Safe Clock Monitor and the Internal External Switch Over mode
#rom 2007 {0x00}
