Chen Guest
| Target not in debug mode? |
Posted: Wed Feb 12, 2003 10:32 am |
I tried out a sample code, it compiled fine, but when I program it in MPLAB, everything seems fine until verification:
Programming Target...
...Erasing Part
...Programming Program Memory
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
...Programming RSBUG
...Programming Configuration Bits
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
.. Config Memory
ICD0083: (CICDController::EnterDebugMode) Target not in debug mode, unable to perform operation
...Programming failed
Any suggestion?
Thanks!
___________________________
Original Post ID: 11603 |
Gavin Guest
| Re: Target not in debug mode? |
Posted: Thu Feb 13, 2003 1:06 pm |
I am having the same problem too... did you ever resolve this issue?
:=I tried out a sample code, it compiled fine, but when I program it in MPLAB, everything seems fine until verification:
:=Programming Target...
:=...Erasing Part
:=...Programming Program Memory
:=...Loading DebugExecutive
:=...Programming DebugExecutive
:=...Programming Debug Vector
:=...Programming RSBUG
:=...Programming Configuration Bits
:=Verifying...
:=...Program Memory
:=...Debug Executive
:=...Debug Vector
:=...Verify Succeeded
:=.. Config Memory
:=ICD0083: (CICDController::EnterDebugMode) Target not in debug mode, unable to perform operation
:=...Programming failed
:=Any suggestion?
:=Thanks!
Original Post ID: 11652 |
poulholmoethomsen Guest
Posted: Mon Feb 17, 2003 8:24 am |
:=...Erasing Part
:=Verifying...
:=...Program Memory
:=...Debug Vector
:=.. Config Memory
:=Any suggestion?
:=Thanks!
In the configuration bit window - Background debug should be disabled.
good luck
Poul
Original Post ID: 11787 |
