Communicating pic16f876 to sensor3
Einly
PostPosted: Mon Nov 18, 2002 8:06 am     Reply with quote
Dear sir,
I've written a program as below to communicate pic16f876 to the sensor with reference to ur advice:
#include <16f876.h>
#use delay (clock=20000000)
#fuses noprotect, nowdt, hs, nolvp
#byte PORTA =5
#byte PORTB =6
#byte PORTC =7
#define READ_SSP() (SSPBUF)
#define WAIT_FOR_SSP() while((SSPSTAT & 1)==0)
#define WRITE_SSP(x) SSPBUF=(x)
#define CLEAR_WCOL() SSPCON = SSPCON & 0x3f
set_tris_b(0);
set_tris_c(0x20);
byte garbage[1];
byte byte_returned;
do
CLEAR_WCOL();
WRITE_SSP(0x02);
WAIT_FOR_SSP();
garbage=READ_SSP();
TRISSDO=1;
WRITE_SSP(garbage);
WAIT_FOR_SSP();
byte_returned=READ_SSP();
TRISSDO=0;
}while(1);
However, error messages appear when I try to compile it. I think that I have misunderstood what you have taught me. Can you please modify the program for me?
Thanks a lot for your help.
Einly
Original Post ID: 9053
Mark
Re: Communicating pic16f876 to sensor3
PostPosted: Mon Nov 18, 2002 9:22 am     Reply with quote
You haven't defined the following
SSPBUF
SSPSTAT
SSPCON
TRISSDO
Regards,
Mark
:=Dear sir,
:=I've written a program as below to communicate pic16f876 to the sensor with reference to ur advice:
:=#include <16f876.h>
:=#use delay (clock=20000000)
:=#fuses noprotect, nowdt, hs, nolvp
:=#byte PORTA =5
:=#byte PORTB =6
:=#byte PORTC =7
:=#define READ_SSP() (SSPBUF)
:=#define WAIT_FOR_SSP() while((SSPSTAT & 1)==0)
:=#define WRITE_SSP(x) SSPBUF=(x)
:=#define CLEAR_WCOL() SSPCON = SSPCON & 0x3f
:=void main()
:= set_tris_b(0);
:= set_tris_c(0x20);
:= byte garbage[1];
:= byte byte_returned;
:= do
:= CLEAR_WCOL();
:= WRITE_SSP(0x02);
:= WAIT_FOR_SSP();
:= garbage=READ_SSP();
:= TRISSDO=1;
:= WRITE_SSP(garbage);
:= WAIT_FOR_SSP();
:= byte_returned=READ_SSP();
:= TRISSDO=0;
:= }while(1);
:=However, error messages appear when I try to compile it. I think that I have misunderstood what you have taught me. Can you please modify the program for me?
:=Thanks a lot for your help.
:=Einly
Original Post ID: 9055
Einly
PostPosted: Mon Nov 18, 2002 10:32 am     Reply with quote
Dear sir,
Thanks for ur reply:)
I'm sorry to say that I've a very poor understanding in using the chip as well as the command.
May I know how should I define them? As I know, they refer to registers in the chip used for synchronous serial port communication.
For your information, the sensor that I refer to is an optical sensor manufactured by Agilent Technologies, i.e. ADNS2051.
Thanks.
Einly
:=You haven't defined the following
:=SSPBUF
:=SSPSTAT
:=SSPCON
:=TRISSDO
:=Regards,
:=Mark
:=:=Dear sir,
:=:=I've written a program as below to communicate pic16f876 to the sensor with reference to ur advice:
:=:=#include <16f876.h>
:=:=#use delay (clock=20000000)
:=:=#fuses noprotect, nowdt, hs, nolvp
:=:=#byte PORTA =5
:=:=#byte PORTB =6
:=:=#byte PORTC =7
:=:=#define READ_SSP() (SSPBUF)
:=:=#define WAIT_FOR_SSP() while((SSPSTAT & 1)==0)
:=:=#define WRITE_SSP(x) SSPBUF=(x)
:=:=#define CLEAR_WCOL() SSPCON = SSPCON & 0x3f
:=:=void main()
:=:= set_tris_b(0);
:=:= set_tris_c(0x20);
:=:= byte garbage[1];
:=:= byte byte_returned;
:=:= do
:=:= CLEAR_WCOL();
:=:= WRITE_SSP(0x02);
:=:= WAIT_FOR_SSP();
:=:= garbage=READ_SSP();
:=:= TRISSDO=1;
:=:= WRITE_SSP(garbage);
:=:= byte_returned=READ_SSP();
:=:= TRISSDO=0;
:=:= }while(1);
:=:=However, error messages appear when I try to compile it. I think that I have misunderstood what you have taught me. Can you please modify the program for me?
:=:=Thanks a lot for your help.
:=:=Einly
Original Post ID: 9063
Mark
PostPosted: Mon Nov 18, 2002 6:35 pm     Reply with quote
Not sure what TRISSDO is. The other are registers in the PIC. Look up there addresses in the datasheet and use the #byte command as you did for PORTA.
:=Dear sir,
:=Thanks for ur reply<img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=I'm sorry to say that I've a very poor understanding in using the chip as well as the command.
:=May I know how should I define them? As I know, they refer to registers in the chip used for synchronous serial port communication.
:=For your information, the sensor that I refer to is an optical sensor manufactured by Agilent Technologies, i.e. ADNS2051.
:=Thanks.
:=Einly
:=:=You haven't defined the following
:=:=SSPBUF
:=:=SSPSTAT
:=:=SSPCON
:=:=TRISSDO
:=:=Regards,
:=:=Mark
:=:=:=Dear sir,
:=:=:=I've written a program as below to communicate pic16f876 to the sensor with reference to ur advice:
:=:=:=#include <16f876.h>
:=:=:=#use delay (clock=20000000)
:=:=:=#fuses noprotect, nowdt, hs, nolvp
:=:=:=#byte PORTA =5
:=:=:=#byte PORTB =6
:=:=:=#byte PORTC =7
:=:=:=#define READ_SSP() (SSPBUF)
:=:=:=#define WAIT_FOR_SSP() while((SSPSTAT & 1)==0)
:=:=:=#define WRITE_SSP(x) SSPBUF=(x)
:=:=:=#define CLEAR_WCOL() SSPCON = SSPCON & 0x3f
:=:=:=void main()
:=:=:= set_tris_b(0);
:=:=:= set_tris_c(0x20);
:=:=:= byte garbage[1];
:=:=:= byte byte_returned;
:=:=:= do
:=:=:= CLEAR_WCOL();
:=:=:= WRITE_SSP(0x02);
:=:=:= WAIT_FOR_SSP();
:=:=:= garbage=READ_SSP();
:=:=:= TRISSDO=1;
:=:=:= WRITE_SSP(garbage);
:=:=:= byte_returned=READ_SSP();
:=:=:= TRISSDO=0;
:=:=:= }while(1);
:=:=:=However, error messages appear when I try to compile it. I think that I have misunderstood what you have taught me. Can you please modify the program for me?
:=:=:=Thanks a lot for your help.
:=:=:=Einly
Original Post ID: 9077
