I need help
Jean Paul
I need help
PostPosted: Thu Nov 14, 2002 8:13 am     Reply with quote
Hi
someone can tell me the possible errors in my code.
my code is for pwm with pin b0 and pin b1 I change the duty cyle
of the pwm. the problem is that I cand view the changes in my scope. I dont know the reason.
thanks
my code is:
#include <16F877.h>
#use delay(clock=1843200)
#fuses XT,NOWDT,NOPROTECT
main() {
long value;
byte data;
SET_TRIS_B( 0xFF );
setup_timer_2(T2_DIV_BY_16,239,1);
setup_ccp1(CCP_PWM);
value=480;
set_pwm1_duty(value); // This sets the time the pulse is
while( TRUE ) {
data = input_b();
data = data && 0x03;
if ( data==0x01)
value=value+192;
if ( data==0x02)
value=value-192;
delay_ms(50);
Original Post ID: 8902
nilsener
Re: I need help
PostPosted: Thu Nov 14, 2002 9:38 am     Reply with quote
Dear,
I get this code running, perhaps it is a problem that your duty_cycle value (480) is greater than 239 (239 sets the time of one period) as in you setup_timer2 statement. I think you will only get PWM if the duty cycle is between 0 and 239.
regards nilsener
void PWM_INIT()
SETUP_CCP1(CCP_PWM); // Set PWM Mode
setup_timer_2(T2_DIV_BY_16, 26, 1); // Set Timer2
SET_PWM1_DUTY(13); // Set Duty to 50\%
} /*End if PWM_INIT*/
:=Hi
:=someone can tell me the possible errors in my code.
:=my code is for pwm with pin b0 and pin b1 I change the duty cyle
:=of the pwm. the problem is that I cand view the changes in my scope. I dont know the reason.
:=thanks
:=my code is:
:=#include <16F877.h>
:=#use delay(clock=1843200)
:=#fuses XT,NOWDT,NOPROTECT
:=main() {
:= long value;
:= byte data;
:= SET_TRIS_B( 0xFF );
:= setup_timer_2(T2_DIV_BY_16,239,1);
:= setup_ccp1(CCP_PWM);
:= value=480;
:= set_pwm1_duty(value); // This sets the time the pulse is
:=while( TRUE ) {
:= data = input_b();
:= data = data && 0x03;
:= if ( data==0x01)
:= value=value+192;
:= if ( data==0x02)
:= value=value-192;
:= delay_ms(100);
:= delay_ms(50);
Original Post ID: 8909
Jean Paul
Re: I need help
PostPosted: Thu Nov 14, 2002 9:50 am     Reply with quote
thanks for your reply
but I thinks my problem is how to detect the bits b0 and b1 of the portB
I use data = (input_b()&& 0x03); to check the status of the
bits 0 an 1 but IT DOESNT WORK
can you tell me another way
thanks
:=Dear,
:=I get this code running, perhaps it is a problem that your duty_cycle value (480) is greater than 239 (239 sets the time of one period) as in you setup_timer2 statement. I think you will only get PWM if the duty cycle is between 0 and 239.
:=regards nilsener
:=void PWM_INIT()
:=SETUP_CCP1(CCP_PWM); // Set PWM Mode
:=setup_timer_2(T2_DIV_BY_16, 26, 1); // Set Timer2
:=SET_PWM1_DUTY(13); // Set Duty to 50\%
:=} /*End if PWM_INIT*/
:=:=Hi
:=:=someone can tell me the possible errors in my code.
:=:=my code is for pwm with pin b0 and pin b1 I change the duty cyle
:=:=of the pwm. the problem is that I cand view the changes in my scope. I dont know the reason.
:=:=thanks
:=:=my code is:
:=:=#include <16F877.h>
:=:=#use delay(clock=1843200)
:=:=#fuses XT,NOWDT,NOPROTECT
:=:=main() {
:=:= long value;
:=:= byte data;
:=:= SET_TRIS_B( 0xFF );
:=:= setup_timer_2(T2_DIV_BY_16,239,1);
:=:= setup_ccp1(CCP_PWM);
:=:= value=480;
:=:= set_pwm1_duty(value); // This sets the time the pulse is
:=:=while( TRUE ) {
:=:= data = input_b();
:=:= data = data && 0x03;
:=:= if ( data==0x01)
:=:= value=value+192;
:=:= if ( data==0x02)
:=:= value=value-192;
:=:= delay_ms(100);
:=:= delay_ms(50);
Original Post ID: 8910
Tomi
Re: I need help
PostPosted: Thu Nov 14, 2002 10:22 am     Reply with quote
"&&" is logical AND. Use "&" to get bit-wise AND:
data = input_b() & 0x03;
:=thanks for your reply
:=but I thinks my problem is how to detect the bits b0 and b1 of the portB
:=I use data = (input_b()&& 0x03); to check the status of the
:=bits 0 an 1 but IT DOESNT WORK
:=can you tell me another way
:=thanks
:=:=Dear,
:=:=I get this code running, perhaps it is a problem that your duty_cycle value (480) is greater than 239 (239 sets the time of one period) as in you setup_timer2 statement. I think you will only get PWM if the duty cycle is between 0 and 239.
:=:=regards nilsener
:=:=void PWM_INIT()
:=:=SETUP_CCP1(CCP_PWM); // Set PWM Mode
:=:=setup_timer_2(T2_DIV_BY_16, 26, 1); // Set Timer2
:=:=SET_PWM1_DUTY(13); // Set Duty to 50\%
:=:=} /*End if PWM_INIT*/
:=:=:=Hi
:=:=:=someone can tell me the possible errors in my code.
:=:=:=my code is for pwm with pin b0 and pin b1 I change the duty cyle
:=:=:=of the pwm. the problem is that I cand view the changes in my scope. I dont know the reason.
:=:=:=thanks
:=:=:=my code is:
:=:=:=#include <16F877.h>
:=:=:=#use delay(clock=1843200)
:=:=:=#fuses XT,NOWDT,NOPROTECT
:=:=:=main() {
:=:=:= long value;
:=:=:= byte data;
:=:=:= SET_TRIS_B( 0xFF );
:=:=:= setup_timer_2(T2_DIV_BY_16,239,1);
:=:=:= setup_ccp1(CCP_PWM);
:=:=:= value=480;
:=:=:= set_pwm1_duty(value); // This sets the time the pulse is
:=:=:=while( TRUE ) {
:=:=:= data = input_b();
:=:=:= data = data && 0x03;
:=:=:= if ( data==0x01)
:=:=:= value=value+192;
:=:=:= if ( data==0x02)
:=:=:= value=value-192;
:=:=:= delay_ms(100);
:=:=:= delay_ms(50);
Original Post ID: 8913
R.J.Hamlett
Re: I need help
PostPosted: Thu Nov 14, 2002 10:50 am     Reply with quote
:=thanks
Yes. Use &, not &&. The former is the 'bitwise' AND operator (will do an 'AND' with your '3', and the input byte). The latter is the _logical_ AND operator. The operator you are using will return 'true', if input_b is logically 'true' (non zero), AND the test pattern is tre (which it is).
:=:=Dear,
:=:=void PWM_INIT()
:=:=:=Hi
:=:=:=thanks
:=:=:=my code is:
:=:=:=main() {
:=:=:= long value;
:=:=:= byte data;
:=:=:= value=480;
Original Post ID: 8917
