16F684 and EEprom
Christian
16F684 and EEprom
PostPosted: Sun Nov 03, 2002 2:03 am     Reply with quote
Hi!
I'm a newbie, and I really have troubble writing and reading
to/from the EEPROM using c compiler, and 16f684.
Anybody who can help?
Anything is usefull to me!!!
Christian
Original Post ID: 8443
Christian
I ment 16F628
PostPosted: Sun Nov 03, 2002 2:11 am     Reply with quote
:=Hi!
:=I'm a newbie, and I really have troubble writing and reading
:=to/from the EEPROM using c compiler, and 16f628.
:=Anybody who can help?
:=Anything is usefull to me!!!
:=Christian
Original Post ID: 8445
johnpcunningham
Re: I ment 16F628
PostPosted: Sun Nov 03, 2002 10:33 am     Reply with quote
Simple to use the built in functions on this one. The general format is:
write_eeprom( address, value );
read_eeprom( address, value );
Here is a code example:
void main{
char i,j,k;
write_eeprom(0x00, 0x11); //write hex 0x11 to location 0
write_eeprom(0x01, 0x22); //write hex 0x22 to location 1
write_eeprom(0x02, 0x33); //write hex 0x33 to location 2
i = read_eeprom(0x00); //i = 0x11
j = read_eeprom(0x01); //j = 0x22
k = read_eeprom(0x02); //k = 0x33
while(1){};
Original Post ID: 8455
Christian
Re: I ment 16F628
PostPosted: Sun Nov 03, 2002 12:50 pm     Reply with quote
Thanks.
Do u know how to print this on the LCD-display?
:=Simple to use the built in functions on this one. The general format is:
:=write_eeprom( address, value );
:=read_eeprom( address, value );
:=Here is a code example:
:=void main{
:=char i,j,k;
:=write_eeprom(0x00, 0x11); //write hex 0x11 to location 0
:=write_eeprom(0x01, 0x22); //write hex 0x22 to location 1
:=write_eeprom(0x02, 0x33); //write hex 0x33 to location 2
:=i = read_eeprom(0x00); //i = 0x11
:=j = read_eeprom(0x01); //j = 0x22
:=k = read_eeprom(0x02); //k = 0x33
:=while(1){};
Original Post ID: 8460
johnpcunningham
Re: I ment 16F628
PostPosted: Sun Nov 03, 2002 12:56 pm     Reply with quote
Your question is vauge. Whcih LCD? What controller is being used; Hitachi, Toshiba, other?
JC
Original Post ID: 8461
Christian
Re: I ment 16F628
PostPosted: Sun Nov 03, 2002 1:23 pm     Reply with quote
Sorry,
I can't seem to find anything on the LCD-display, but: dmc16207
what do u mean controller? pic16F628? Bluebird?
:=Your question is vauge. Whcih LCD? What controller is being used; Hitachi, Toshiba, other?
:=JC
Original Post ID: 8465
Christian Bech
Re: I ment 16F628
PostPosted: Sun Nov 03, 2002 2:25 pm     Reply with quote
Hi.
16X2 hitachi, is what I got. can u help?
Thx
:=JC
Original Post ID: 8466
johnpcunningham
Re: I ment 16F628
PostPosted: Mon Nov 04, 2002 12:06 pm     Reply with quote
<font face="Courier New" size=-1>OK, the DMC16207 LCD you are using is made by Optrex. The controller that it uses is an Hitachi HD44780. The technical spec can be downloaded here:
<a href="http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf" TARGET="_blank"> <a href="http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf" TARGET="_blank"> <a href="http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf" TARGET="_blank"> <a href="http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf" TARGET="_blank"> <a href="http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf" TARGET="_blank">http://www.optrex.com/SiteImages/PartList/SPEC/16207cae.pdf</a></a></a></a></a>
To program your software you should download this:
<a href="http://www.optrex.com/pdfs/Dmcman_full.pdf" TARGET="_blank"> <a href="http://www.optrex.com/pdfs/Dmcman_full.pdf" TARGET="_blank"> <a href="http://www.optrex.com/pdfs/Dmcman_full.pdf" TARGET="_blank"> <a href="http://www.optrex.com/pdfs/Dmcman_full.pdf" TARGET="_blank"> <a href="http://www.optrex.com/pdfs/Dmcman_full.pdf" TARGET="_blank">http://www.optrex.com/pdfs/Dmcman_full.pdf</a></a></a></a></a>
Generally, you read and write data to the LCD. You use an 8 bit port, and 3 other pins RS, E, and RW to control the data flow. The 3 pins are used to strobe in the data and to tell the Hitcahi controller if it is a command or data.
I'm sure you will ahve a lot of questions. Here are some funciton calls that I have used to interface to this module to get you started:
<PRE>
#ifndef __DMC_H
/* LCD COMMANDS */
/*clears the display & address */
#define clear_display 0x01
/*sets the curser to the home position*/
#define cursor_home 0x02
#define entry_mode 0x06
/*decrements the cursor after writing data */
#define write_dec 0x05
/*increments the cursor after writing data*/
#define write_inc 0x06
/*display off, cursor off and no blink*/
#define display_off 0x08
/*display on, cursor off and no blink*/
#define display_on 0x0c
/*display on, cursor on and no blink*/
#define cursor_on 0x0E
/*display on, cursor on and blink*/
#define blink_on 0x0F
/*8 bit interface and $ of lines on LCD */
#define function 0x38
/* really 0x00 but bit 6 is always a 1 */
#define cg_ram_base 0x40
/* really 0x00 but bit 7 is always a 1 */
#define dd_ram 0x80
/*base address of each of the 4 lines */
#define lcd_line1 0x80 /* bit 7 is always set, i.e. $80 = $00*/
#define lcd_line2 0xC0 /* $C0 = $40 */
#define lcd_line3 0x94 /* $C0 = $14 */
#define lcd_line4 0xD4 /* $C0 = $54 */
#define tree_text 0x00 /* ascii 00 */
#define degree_text 0x01 /* ascii 01 */
const char line_1[] ="WRITING LOCATION: ";
const char line_2[] ="WRITE VALUE IS: ";
const char line_3[] ="READING LOCATION: ";
const char line_4[] ="READ VALUE IS: ";
const char tree[8] ={0x04,0x0e,0x0e,0x1f,0x1f,0x04,0x04,0x04};
const char degree[8] ={0x1c,0x14,0x01c,0x00,0x00,0x00,0x00,0x00};
//DMC 20481 CONNECTIONS//
#define LCD_RS PIN_E0
#define LCD_RW PIN_E1
#define LCD_E PIN_E2
#define DATA_PORT PORTD
/************DMC 20481 LCD connections****************
pin1 Vss
pin2 Vcc (5 volts)
pin3 Vee (connect through a 1K pot to ground to control contrast)
pin4 RS (strobe data, use 4.7K pullup)
pin5 RW (read/writeuse 4.7K pull-down)
pin6 E (enable datause 4.7K pullup)
pin7 D0
pin8 D1
pin9 D2
pin10 D3
pin11 D4
pin12 D5
pin13 D6
pin14 D7
pin15 A (LED ANODE - tie to Vcc)
pin16 K (LED CATHODE - connect through a 1K pot to
ground to control backlighting)
/* FUNCTIONS LISTED BELOW */
void write_data(char text)
OUTPUT_HIGH(LCD_RS); /* RS pin set high for data */
delay_us(100); /* delay 100us*/
PORTD=text; /* Put data on 8 bit port*/
delay_us(100); /* delay 100us */
OUTPUT_LOW(LCD_E); /* E pin brought low*/
OUTPUT_HIGH(LCD_E); /* E pin brought high*/
delay_us(1); /* delay 1000us */
void write_command(char command)
OUTPUT_LOW(LCD_RS); /* RS pin set low for command*/
PORTD=command; /* Put data on 8 bit port*/
delay_us(1000); /* delay 100us*/
Delay_us(100); /* delay 100us*/
/* write a line */
void scroll_line1()
char i=0;
char j=19;
char k=0;
while (j != 0){
write_command(lcd_line1 + j); /* set pointer on LCD to line 1*/
k++;
while( i != k){
write_data(line_1[i++]);
i=0;
j--;
/* write a line */
void scroll_line2()
char i=0;
char j=19;
char k=0;
while (j != 0){
write_command(lcd_line2 + j); /* set pointer on LCD to line 1*/
k++;
while( i != k){
write_data(line_2[i++]);
i=0;
j--;
/* write a line */
void write_line1()
char i=0;
write_command(lcd_line1);
/* Now write the string to LCDs line 1 */
while (line_1[i]!=0x00)
{write_data(line_1[i++]);}
void write_line2()
char i=0;
write_command(lcd_line2);
while (line_2[i]!=0x00)
{write_data(line_2[i++]);}
void write_line3()
char i=0;
write_command(lcd_line3); /* set pointer on LCD to line 1*/
while (line_3[i]!=0x00) /* Now write the string to LCDs line 1 */
{write_data(line_3[i++]);}
void write_line4()
char i=0;
write_command(lcd_line4); /* set pointer on LCD to line 1*/
while (line_4[i]!=0x00) /* Now write the string to LCDs line 1 */
{write_data(line_4[i++]);}
/* write Christmas tree data into LCD memory at base of CG RAM location*/
void write_cgr_tree()
char i =0;
write_command(cg_ram_base); /* send command ($40) to set CGR RAM at 0x00 */
while (i<8) /* Now write the 8 data bytes to LCDs CGR address 0x00*/
{write_data(tree[i++]);}
/* write degree symbol data into LCD memory at base of CG RAM location*/
void write_cgr_degree()
char i =0;
write_command(cg_ram_base + 8); /* send command ($40) + offset to set CGR RAM at 0x01 */
while (i<8) /* Now write the 8 data bytes to LCDs CGR address 0x01*/
{write_data(degree[i++]);}
void init_lcd(void)
//SET UP THE PORTS I_O //
TRISA = 0x00;
PORTA = 0xFF;
TRISB = 0x00;
PORTB = 0xFF;
TRISD = 0x00;
PORTD = 0xFF;
TRISE = 0x00;
PORTE = 0x05; //MUST BE A "101" ON STARTUP
/* set up 4/8 bit interface and No. of lines */
delay_ms(150);
write_command(function);
delay_ms(150);
/* Clear display */
write_command(clear_display);
delay_ms(150);
/* Set cursor at line 1, column 0 */
write_command(cursor_home);
delay_ms(150);
/* Display on, cursor not on */
write_command(display_on);
delay_us(100);
/* increment address after data writes */
write_command(entry_mode);
delay_us(100);
void lcd_screen_bootup(void)
char i =0;
scroll_line1(); /* write to line 1 */
scroll_line2(); /* write to line 1 */
/* Blink Screen once a second */
while (i!=5)
write_command(display_off); /* turn off screen */
delay_ms(250);
write_command(display_on); /* turn screen back on */
delay_ms(250);
i++;
/* write a line */
void blink_lcd()
delay_ms(200);
delay_ms(800);
</font>
Original Post ID: 8494
