SPI help... clocking issue maybe?
Trevor
PostPosted: Sat Nov 02, 2002 9:47 pm     Reply with quote
Trying to use SPI to communicate between two PIC's.
One set up as master, and provides clock.
Another set up as slave. All the printf statements are just used to see what's happening via RS232 link.
Below is a section of the code which is suppose to interract with one another... any suggestions?
Thanks...
//Master
// requestPosition
void requestPosition()
// ...spi stuff
byte low_byte, high_byte;
output_low(PIN_PIC_CS); //select slave
spi_write(REQUEST_POSITION1);
printf("Requesting position x from slave...\r\n");
output_high(PIN_PIC_CS); //release slave
delay_cycles(50); //give slave time to vector
output_low(PIN_PIC_CS); //select slave again
low_byte = spi_read();
printf("Position x is \%x\r\n", low_byte);
spi_write(REQUEST_POSITION2);
printf("Requesting position y from slave...\r\n");
delay_cycles(50);
high_byte = spi_read();
printf("Position y is \%x\r\n", high_byte);
// Slave
// SPI Communication
#int_ssp
ssp_isr()
int command;
int position_x;
int position_y;
SSPOV = FALSE; //clear possible overwrite
command = spi_read();
switch(command)
case '0': //request position_x
printf("Position x requested... \r\n");
position_x = 0x04;
spi_write(position_x);
printf("Position x sent to master... \r\n");
case '1': //request position y
printf("Position y requested... \r\n");
position_y = 0x02;
spi_write(position_y);
SSPIF = FALSE; //clear follow-on interrupts
Original Post ID: 8442
R.J.Hamlett
Re: SPI help... clocking issue maybe?
PostPosted: Sun Nov 03, 2002 8:16 am     Reply with quote
:=Trying to use SPI to communicate between two PIC's.
:=One set up as master, and provides clock.
:=Another set up as slave. All the printf statements are just used to see what's happening via RS232 link.
:=Below is a section of the code which is suppose to interract with one another... any suggestions?
:=Thanks...
I have never played with useing the CS (haven't got enough pins for this!), but I suspect there may be a timing issue that I have outlined in the code...
:=//Master
:=// requestPosition
:=void requestPosition()
:= // ...spi stuff
:= byte low_byte, high_byte;
:= output_low(PIN_PIC_CS); //select slave
:= spi_write(REQUEST_POSITION1);
:= printf("Requesting position x from slave...\r\n");
:= output_high(PIN_PIC_CS); //release slave
Are you _sure_ the SPI has completed here?. I think you will find that the SPI write, only sends the character to the hardware, and returns immediately. Hence (depending in the SPI speed selected), the character won't actually be sent till several uSecs latter. Try clearing the read register before sending, and then you can poll the SPI, till there is a character to read. This will imply the character has transferred in the opposite direction, allowing you to drop the CS.
:= delay_cycles(50); //give slave time to vector
Again are you sure this is enough. Depends on the chip, but once the SPI interrupt occurs, on a 18F chip for example, there may be about 20 cycles before you even enter the handler code, and this is assuming the chip does not have interrupts disabled at any time. You have to add the length of the longest routine that disables interrupts, the time needed to save all the registers, and the length of your handler together to ensure that a response has been generated. I have to use 200 cycles delay to cover all this!...
:= output_low(PIN_PIC_CS); //select slave again
:= low_byte = spi_read();
:= printf("Position x is \%x\r\n", low_byte);
:= spi_write(REQUEST_POSITION2);
:= printf("Requesting position y from slave...\r\n");
:= high_byte = spi_read();
:= printf("Position y is \%x\r\n", high_byte);
:=// Slave
:=// SPI Communication
:=#int_ssp
:=ssp_isr()
:= int command;
:= int position_x;
:= int position_y;
:= SSPOV = FALSE; //clear possible overwrite
:= command = spi_read();
:= switch(command)
:= case '0': //request position_x
:= printf("Position x requested... \r\n");
:= position_x = 0x04;
:= spi_write(position_x);
:= printf("Position x sent to master... \r\n");
:= break;
:= case '1': //request position y
:= printf("Position y requested... \r\n");
:= position_y = 0x02;
:= spi_write(position_y);
:= break;
:= SSPIF = FALSE; //clear follow-on interrupts
Good Luck.
Original Post ID: 8448
Woody
PostPosted: Mon Nov 04, 2002 2:30 am     Reply with quote
In master mode: the function spi_write() causes a byte to be clocked out and the code generated will wait until transmission is complete by checking SSPSTAT bit 0; the function spi_read() only reads the contents of the SSPBUF register.
From your code a command is clocked out to the slave which upon reciept would then presumably write a value into it's SSPBUF.
In order to retrieve this value you need to clock out a dummy value from the master with the chip selected, before your call to spi_read() since the clock is only generated by the master device.
Best Regards
Original Post ID: 8473
R.J.Hamlett
PostPosted: Mon Nov 04, 2002 3:58 am     Reply with quote
:=In master mode: the function spi_write() causes a byte to be clocked out and the code generated will wait until transmission is complete by checking SSPSTAT bit 0; the function spi_read() only reads the contents of the SSPBUF register.
This depends on the compiler, but on at least two versions, this wait is not performed...
I have run into exactly this problem, and ended up taking the assembler code apart. It waited _before_ sending the byte, to verify that the register was empty, but did not wait for the character to send....
:=From your code a command is clocked out to the slave which upon reciept would then presumably write a value into it's SSPBUF.
:=In order to retrieve this value you need to clock out a dummy value from the master with the chip selected, before your call to spi_read() since the clock is only generated by the master device.
:=Best Regards
Original Post ID: 8476
