		| View previous topic :: View next topic   |
			SL1978 Guest
				| 18f452 EEPROM not working |
				 Posted: Sun Aug 11, 2002 7:22 pm     |
				I program my 18f452 with PCH 3.06. I had downloaded The suggested solution form mark and use in my program. Unfortunately it still doesn't work. The EEDATA always hold the last written value when we try to read back the eeprom contain.
Attached is a code of mine, can you kindly consult me where is the problem?
Thanks & regards,
Law
///my program///
#include <18f452.h>
#fuses xt,noprotect,nowdt,put,brownout,nolvp
#use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
//--------------------------- old version -------------------------------------
#define EEADR 0xFA9
#define EEDATA 0xFA8
#define EECON1 0xFA6
#define RD 0
#define WR 1
#define WREN 2
#define WRERR 3
#define FREE 4
#define CFGS 6
#define EEPGD 7
#define EECON2 0xFA7
#define PIR2 0xFA1
#define EEIF 4
void writeeeprom(int address, int data)
bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
(int)*EEADR = address; // Load our address
(int)*EEDATA = data; // Load our data
bit_clear(*EECON1, EEPGD); // Point to data memory
bit_set(*EECON1, WREN); // Enable writes
// Microchip recommends disabling ints here
disable_interrupts(GLOBAL);
(int)*EECON2 = 0x55; // Write 0x55
(int)*EECON2 = 0xAA; // Write 0xAA
bit_set(*EECON1, WR); // Set WR to begin write
// Ok to turn back on ints
// Wait for the write to complete
while (!bit_test(*PIR2, EEIF));
bit_clear(*EECON1, WREN); // disable writes
int readeeprom(int address)
bit_set(*EECON1, RD); // EEPROM Read
return(*EEDATA); // Return with our value
main()
{ int8 ctr, ctr2, ctr3,i;
SET_UART_SPEED(19200);
for(ctr = 100; ctr<=110; ctr++)
ctr2 = ctr - 100 + 1;
writeeeprom(ctr, ctr2);
ctr = 100;
putc(13);
ctr3 = readeeprom(ctr);
printf("addr = \%u eep = \%u", ctr,ctr3);
if(ctr<110)
ctr++;
ctr=100;
delay_ms(600);
___________________________
	Original Post ID: 6317 |
			Peter H Anderson Guest
				| Re: 18f452 EEPROM not working |
				 Posted: Sun Aug 11, 2002 10:28 pm     |
				I struggled with this for some time and discovered the cfgs bit must be cleared.
Attached are sample routines which I have recently tested.  Note that I use a header file which defines all SFRs and bit within the SFRs.  However, you should be able to read this.
Note that when I wrote this CCS had not defined the EE interrupt for the PIC18F.  Thus, I am simply waiting 10 ms for the programming.
byte read_data_eeprom(byte adr)
   cfgs = 0;		// this is critical
   EEADR=adr;
   eepgd = 0;		// select data EEPROM
   rd=1;	// set the read bit
   return(EEDATA);
void write_data_eeprom(byte adr, byte d)
   byte gie_flag;
   cfgs = 0;
   EEADR = adr;
   EEDATA = d;
#ifdef EE_INT
   eeif = 0;
   eeie = 1;
   peie = 1;
   ee_int_occ = FALSE;
   if (gie)	// if gie is enabled, turn it off
	   gie_flag = TRUE;
	   while(gie)
		   gie = 0;
	   gie_flag = FALSE;
   wren = 1;		// write enable
   EECON2 = 0x55;	// protection sequence
   EECON2 = 0xaa;
   wr = 1;		// begin programming sequence
#ifdef EE_INT
   gie = 1;
   while(!ee_int_occ)
   eeie = 0;
   while(gie)
	   gie = 0;
#else
   delay_ms(10);
   wren = 0;		// disable write enable
   if (gie_flag)
	   gie = 1;
	   while(gie)
		   gie = 0;
Peter H Anderson,  <a href="http://www.phanderson.com," TARGET="_blank">http://www.phanderson.com,</a> pha(at)phanderson.com
:=I program my 18f452 with PCH 3.06. I had downloaded The suggested solution form mark and use in my program. Unfortunately it still doesn't work. The EEDATA always hold the last written value when we try to read back the eeprom contain.
:=Attached is a code of mine, can you kindly consult me where is the problem?
:=Thanks & regards,
:=Law
:=///my program///
:=#include <18f452.h>
:=#fuses xt,noprotect,nowdt,put,brownout,nolvp
:=#use delay(clock=4000000)
:=#use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
:=//--------------------------- old version -------------------------------------
:=#define EEADR 0xFA9
:=#define EEDATA 0xFA8
:=#define EECON1 0xFA6
:=#define RD 0
:=#define WR 1
:=#define WREN 2
:=#define WRERR 3
:=#define FREE 4
:=#define CFGS 6
:=#define EEPGD 7
:=#define EECON2 0xFA7
:=#define PIR2 0xFA1
:=#define EEIF 4
:=void writeeeprom(int address, int data)
:=bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
:=(int)*EEADR = address; // Load our address
:=(int)*EEDATA = data; // Load our data
:=bit_clear(*EECON1, EEPGD); // Point to data memory
:=bit_set(*EECON1, WREN); // Enable writes
:=// Microchip recommends disabling ints here
:=disable_interrupts(GLOBAL);
:=(int)*EECON2 = 0x55; // Write 0x55
:=(int)*EECON2 = 0xAA; // Write 0xAA
:=bit_set(*EECON1, WR); // Set WR to begin write
:=// Ok to turn back on ints
:=enable_interrupts(GLOBAL);
:=// Wait for the write to complete
:=while (!bit_test(*PIR2, EEIF));
:=bit_clear(*EECON1, WREN); // disable writes
:=int readeeprom(int address)
:=bit_set(*EECON1, RD); // EEPROM Read
:=return(*EEDATA); // Return with our value
:=main()
:={ int8 ctr, ctr2, ctr3,i;
:=SET_UART_SPEED(19200);
:=for(ctr = 100; ctr<=110; ctr++)
:=ctr2 = ctr - 100 + 1;
:=writeeeprom(ctr, ctr2);
:=ctr = 100;
:=while(1)
:=putc(13);
:=ctr3 = readeeprom(ctr);
:=printf("addr = \%u eep = \%u", ctr,ctr3);
:=if(ctr<110)
:=ctr++;
:=else
:=ctr=100;
:=delay_ms(600);
	Original Post ID: 6321 |
			Mark
				 Posted: Tue Aug 13, 2002 1:58 pm     |
				I compiled this with 3.085 and everything seems okay (running on an ice2000).  Here is the lst file.  Note that I commented out the printf since I was not connected to a PC.  Instead, I read the EEPROM and checked the value of ctr3 after each read.
0000:  GOTO   0084
....................  ///my program///
.................... #include <18f452.h>
....................  //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
.................... #list
.................... #fuses xt,noprotect,nowdt,put,brownout,nolvp
.................... #use delay(clock=4000000)
0054:  CLRF   FEA
0056:  MOVLW  0B
0058:  MOVWF  FE9
005A:  MOVF   FEF,W
005C:  BTFSC  FD8.2
005E:  GOTO   0080
0062:  MOVLW  01
0064:  MOVWF  01
0066:  CLRF   00
0068:  DECFSZ 00,F
006A:  BRA    0068
006C:  DECFSZ 01,F
006E:  BRA    0066
0070:  MOVLW  4A
0072:  MOVWF  00
0074:  DECFSZ 00,F
0076:  BRA    0074
0078:  NOP
007A:  NOP
007C:  DECFSZ FEF,F
007E:  BRA    0062
0080:  GOTO   0102 (RETURN)
.................... #use rs232(xmit=PIN_c6,rcv=PIN_c7,ERRORS)
.................... //--------------------------- old version -------------------------------------
.................... #define EEADR 0xFA9
.................... #define EEDATA 0xFA8
.................... #define EECON1 0xFA6
.................... #define RD 0
.................... #define WR 1
.................... #define WREN 2
.................... #define WRERR 3
.................... #define FREE 4
.................... #define CFGS 6
.................... #define EEPGD 7
.................... #define EECON2 0xFA7
.................... #define PIR2 0xFA1
.................... #define EEIF 4
.................... void writeeeprom(int address, int data)
.................... bit_clear(*PIR2, EEIF); // Make sure that the int flag is cleared
0004:  BCF    FA1.4
.................... (int)*EEADR = address; // Load our address
0006:  MOVFF  0A,FA9
.................... (int)*EEDATA = data; // Load our data
000A:  MOVFF  0B,FA8
.................... bit_clear(*EECON1, EEPGD); // Point to data memory
000E:  BCF    FA6.7
.................... bit_set(*EECON1, WREN); // Enable writes
0010:  BSF    FA6.2
.................... // Microchip recommends disabling ints here
.................... disable_interrupts(GLOBAL);
0012:  BCF    FF2.6
0014:  BCF    FF2.7
0016:  BTFSC  FF2.7
0018:  GOTO   0014
.................... (int)*EECON2 = 0x55; // Write 0x55
001C:  MOVLW  55
001E:  MOVWF  FA7
.................... (int)*EECON2 = 0xAA; // Write 0xAA
0020:  MOVLW  AA
0022:  MOVWF  FA7
.................... bit_set(*EECON1, WR); // Set WR to begin write
0024:  BSF    FA6.1
.................... // Ok to turn back on ints
.................... enable_interrupts(GLOBAL);
0026:  MOVLW  C0
0028:  IORWF  FF2,F
.................... // Wait for the write to complete
.................... while (!bit_test(*PIR2, EEIF));
002A:  BTFSS  FA1.4
002C:  GOTO   002A
0030:  GOTO   0034
.................... bit_clear(*EECON1, WREN); // disable writes
0034:  BCF    FA6.2
0036:  BCF    FA1.4
0038:  GOTO   00C2 (RETURN)
.................... int readeeprom(int address)
003C:  MOVFF  0A,FA9
0040:  BCF    FA6.7
.................... bit_set(*EECON1, RD); // EEPROM Read
0042:  BSF    FA6.0
0044:  MOVFF  0A,FA9
0048:  BCF    FA6.7
004A:  BSF    FA6.0
.................... return(*EEDATA); // Return with our value
004C:  MOVF   FA8,W
004E:  MOVWF  01
0050:  GOTO   00DE (RETURN)
.................... main()
.................... { int8 ctr, ctr2, ctr3,i;
0084:  CLRF   FEA
0086:  CLRF   FE9
0088:  CLRF   FC1
008A:  CLRF   05
008C:  MOVLW  19
008E:  MOVWF  FAF
0090:  MOVLW  26
0092:  MOVWF  FAC
0094:  MOVLW  90
0096:  MOVWF  FAB
.................... SET_UART_SPEED(19200);
0098:  MOVLW  0C
009A:  MOVWF  FAF
009C:  MOVLW  26
009E:  MOVWF  FAC
.................... for(ctr = 100; ctr<=110; ctr++)
00A0:  MOVLW  64
00A2:  MOVWF  06
00A4:  MOVF   06,W
00A6:  SUBLW  6E
00A8:  BTFSS  FD8.0
00AA:  GOTO   00C8
.................... ctr2 = ctr - 100 + 1;
00AE:  MOVLW  64
00B0:  SUBWF  06,W
00B2:  ADDLW  01
00B4:  MOVWF  07
.................... writeeeprom(ctr, ctr2);
00B6:  MOVFF  06,0A
00BA:  MOVFF  07,0B
00BE:  GOTO   0004
00C2:  INCF   06,F
00C4:  GOTO   00A4
.................... ctr = 100;
00C8:  MOVLW  64
00CA:  MOVWF  06
.................... while(1)
.................... putc(13);
00CC:  MOVLW  0D
00CE:  BTFSS  F9E.4
00D0:  GOTO   00CE
00D4:  MOVWF  FAD
.................... ctr3 = readeeprom(ctr);
00D6:  MOVFF  06,0A
00DA:  GOTO   003C
00DE:  MOVFF  01,08
.................... //printf("addr = \%u eep = \%u", ctr,ctr3);
.................... if(ctr<110)
00E2:  MOVF   06,W
00E4:  SUBLW  6D
00E6:  BTFSS  FD8.0
00E8:  GOTO   00F2
.................... ctr++;
00EC:  INCF   06,F
.................... else
00EE:  GOTO   00F6
.................... ctr=100;
00F2:  MOVLW  64
00F4:  MOVWF  06
.................... delay_ms(600);
00F6:  MOVLW  03
00F8:  MOVWF  0A
00FA:  MOVLW  C8
00FC:  MOVWF  0B
00FE:  GOTO   0054
0102:  DECFSZ 0A,F
0104:  BRA    00FA
0106:  GOTO   00CC
010A:  SLEEP
Mark
:=Thanks & regards,
:=Law
:=///my program///
:=#define RD 0
:=#define WR 1
:=#define WREN 2
:=#define WRERR 3
:=#define FREE 4
:=#define CFGS 6
:=#define EEPGD 7
:=#define EEIF 4
:=main()
:=ctr = 100;
:=while(1)
:=putc(13);
:=if(ctr<110)
:=ctr++;
:=else
:=ctr=100;
:=delay_ms(600);
	Original Post ID: 6348 |
			Jay Guest
				 Posted: Wed Oct 16, 2002 1:50 am     |
				I had the same problem: writing nor reading to and from the EEPROM did work. (18f452)
Now I 'manually' clear the CFGS bit in EECON1 (FA6h)
#ASM
  bcf EECON1,6	// solve bug
#ENDASM
And it works!
BTW: I'm using v3.089 and I think this bug is solved in later updates, but my support has run out.
Thanks Peter!
	Original Post ID: 7870 |
