Bit control
dongseong
Bit control
PostPosted: Sun Oct 06, 2002 11:45 am     Reply with quote
I modified my code, but it doesn't work at all.
Could you please whay the problem is?
Before)
output_high(PIN_C2);
output_high(PIN_C5);
output_high(PIN_B0);
output_high(PIN_B1); // all these worked well.
After)
int *LED[4];
int i;
LED[0] = 58; //actual bit address of PIN_C2
LED[1] = 61; //actual bit address of PIN_C5
LED[2] = 48; //actual bit address of PIN_B0
LED[3] = 49; //actual bit address of PIN_B1
for(i=0; i<4; i++)
{ *LED[i] = 1; } // This doesn't work.
If my trial is fundermantally wrong, what will the way
to control each bits by relative addressing?
Original Post ID: 7481
matt maberino
Re: Bit control
PostPosted: Sun Oct 06, 2002 2:16 pm     Reply with quote
:=Hello,
:=I modified my code, but it doesn't work at all.
:=Could you please whay the problem is?
:=Before)
:=output_high(PIN_C2);
:=output_high(PIN_C5);
:=output_high(PIN_B0);
:=output_high(PIN_B1); // all these worked well.
:=After)
:=int *LED[4];
:=int i;
:=LED[0] = 58; //actual bit address of PIN_C2
:=LED[1] = 61; //actual bit address of PIN_C5
:=LED[2] = 48; //actual bit address of PIN_B0
:=LED[3] = 49; //actual bit address of PIN_B1
:=for(i=0; i<4; i++)
:={ *LED[i] = 1; } // This doesn't work.
:=If my trial is fundermantally wrong, what will the way
:=to control each bits by relative addressing?
i like this code, i haven't had a chance to check it, but my first instinct is to suspect the tris register's
- matt
Original Post ID: 7490
dongseong
Re: Bit control
PostPosted: Sun Oct 06, 2002 2:34 pm     Reply with quote
:=:=Hello,
:=:=I modified my code, but it doesn't work at all.
:=:=Could you please explaine me what the problem is?
:=:=Before)
:=:=output_high(PIN_C2);
:=:=output_high(PIN_C5);
:=:=output_high(PIN_B0);
:=:=output_high(PIN_B1); // all these worked well.
:=:=After)
:=:=int *LED[4];
:=:=int i;
:=:=LED[0] = 58; //actual bit address of PIN_C2
:=:=LED[1] = 61; //actual bit address of PIN_C5
:=:=LED[2] = 48; //actual bit address of PIN_B0
:=:=LED[3] = 49; //actual bit address of PIN_B1
:=:=for(i=0; i<4; i++)
:=:={ *LED[i] = 1; } // This doesn't work.
:=:=If my trial is fundermantally wrong, what will the way
:=:=to control each bits by relative addressing?
:=i like this code, i haven't had a chance to check it, but my first instinct is to suspect the tris register's
:=- matt
Thanks for quick response!
My set_tris() are for all output
set_tris_b(0);
set_tris_c(0);
Regards
Dong
Original Post ID: 7492
R.J.Hamlett
Re: Bit control
PostPosted: Sun Oct 06, 2002 2:48 pm     Reply with quote
:=Hello,
:=Before)
:=After)
:=int *LED[4];
:=int i;
Start with the simple statement from the manual:
"Arrays of SHORT, and pointers to SHORT are not permitted". The bits are shorts, and you are trying to use the numbers as pointer, so what you have will not work. You would end up setting the memory addresses 58,61,48 & 49 to 1...
There are several ways to get close to this, but none with the array quite as shown. One method, would be something like:
#define SET_BIT(x) = BIT_SET(*(x >> 3),x & 7)
Then:
SET_BIT(LED[i]);
should work.
This is based on the fact that the memory address of the port register is stored shifted left 3 bits in the numbers given by the normal defines, and the bit number, is the low three bits. Hence the 'SET_BIT' declaration, will remove the bottom three bits, and use this as the address of the register to be updated, then get the bit number from the low three bits, and do the actual 'set'.
Original Post ID: 7493
johnpcunningham
Re: Bit control
PostPosted: Sun Oct 06, 2002 2:54 pm     Reply with quote
<font face="Courier New" size=-1>:=Hello,
:=Before)
:=After)
:=int *LED[4];
:=int i;
You are modifying a register, not the output pin. WHen you did this:
LED[0] = 58;
LED[1] = 61;
LED[2] = 48;
LED[3] = 49;
All you did was initialize 4 indexed variables to 58, 61, 48, and 49........not the addresses
If you want to output to the port directly, then you need to write to the PORTB register itself. Use a #byte statement to define the PICs register map and then you can address it directly. Here is an example for you:
// MEMORY LOCATIONS FOR EACH REGISTER (if needed)//
#byte INDF = 0x0000
#byte TMR0 = 0x0001
#byte PCL = 0x0002
#byte STATUS = 0x0003
#byte FSR = 0x0004
#byte PORTA = 0x0005
#byte PORTB = 0x0006
#byte PORTC = 0x0007
#byte PORTD = 0x0008
#byte PORTE = 0x0009
#byte PCLATH = 0x000A
#byte INTCON = 0x000B
#byte PIR1 = 0x000C
#byte PIR2 = 0x000D
#byte TMR1L = 0x000E
#byte TMR1H = 0x000F
#byte T1CON = 0x0010
#byte TMR2 = 0x0011
#byte T2CON = 0x0012
#byte SSPBUF = 0x0013
#byte SSPCON = 0x0014
#byte CCPR1L = 0x0015
#byte CCPR1H = 0x0016
#byte CCP1CON = 0x0017
#byte RCSTA = 0x0018
#byte TXREG = 0x0019
#byte RCREG = 0x001A
#byte CCPR2L = 0x001B
#byte CCPR2H = 0x001C
#byte CCP2CON = 0x001D
#byte ADRESH = 0x001E
#byte ADCON0 = 0x001F
#byte OPTION_REG = 0x0081
#byte TRISA = 0x0085
#byte TRISB = 0x0086
#byte TRISC = 0x0087
#byte TRISD = 0x0088
#byte TRISE = 0x0089
#byte PIE1 = 0x008C
#byte PIE2 = 0x008D
#byte PCON = 0x008E
#byte SSPCON2 = 0x0091
#byte PR2 = 0x0092
#byte SSPADD = 0x0093
#byte SSPSTAT = 0x0094
#byte TXSTA = 0x0098
#byte SPBRG = 0x0099
#byte ADRESL = 0x009E
#byte ADCON1 = 0x009F
#byte EEDATA = 0x010C
#byte EEADR = 0x010D
#byte EEDATH = 0x010E
#byte EEADRH = 0x010F
#byte EECON1 = 0x018C
#byte EECON2 = 0x018D
//PORT B conntections//
#define LED0 PIN_B0
#define LED1 PIN_B1
#define LED2 PIN_B2
void main (){
//init the port
set_tris_b(0x00);
PORTB = 0xFF;
delay_us(100);
//turn off leds with direct port access (lower bits)
PORTB = (PORTB & 0xFF);
delay_us(100);
//turn on leds with direct port access (lower bits)
PORTB = (PORTB | 0xF8);
//turn off leds with direct bit access
output_high(LED0);
output_high(LED1);
output_high(LED2);
delay_us(100);
output_low(LED0);
output_low(LED1);
output_low(LED2);
delay_us(100);
while(1){}
Original Post ID: 7495
dongseong
Re: Bit control
PostPosted: Sun Oct 06, 2002 7:13 pm     Reply with quote
:=:=Hello,
:=:=Could you please whay the problem is?
:=:=Before)
:=:=After)
:=:=int *LED[4];
:=:=int i;
:=Start with the simple statement from the manual:
:="Arrays of SHORT, and pointers to SHORT are not permitted". The bits are shorts, and you are trying to use the numbers as pointer, so what you have will not work. You would end up setting the memory addresses 58,61,48 & 49 to 1...
:=There are several ways to get close to this, but none with the array quite as shown. One method, would be something like:
:=#define SET_BIT(x) = BIT_SET(*(x >> 3),x & 7)
:=Then:
:= SET_BIT(LED[i]);
:=should work.
:=This is based on the fact that the memory address of the port register is stored shifted left 3 bits in the numbers given by the normal defines, and the bit number, is the low three bits. Hence the 'SET_BIT' declaration, will remove the bottom three bits, and use this as the address of the register to be updated, then get the bit number from the low three bits, and do the actual 'set'.
:=Best Wishes
Hi, Thanks for the answer.
However, my problem has'n been solved yet.
To isolate other effects, I worte
BIT_SET(*(7 >> 3),1 & 7); //in order to turn on PORTC bit 1,
//but it didn't work, and
BIT_SET(*7, 1); // as manual recommends, but
// din't work either. Manual didn't talk about
// 3 bits shifting
Since
output_high(PIN_C1); always work, I believe others,
including my hardware and TRIS are OK.
The purpose of this is to use bit controls inside
for loop, without repeating output_high() function.
Is there any other way to do it?
Best regards
Dong
Original Post ID: 7509
Mark
Re: Bit control
PostPosted: Sun Oct 06, 2002 7:44 pm     Reply with quote
:=:=:=Hello,
Take a look at the following listings. The first uses fast_io.
.................... #device PIC16F876
.................... #list
.................... #use fast_io(C)
.................... void main(void)
0004: CLRF 04
0007: SLEEP
.................... bit_set(*7,1);
0005: BSF 07,1
.................... output_high(PIN_C1);
0006: BSF 07,1
The next one does not use fast_io
0004: CLRF 04
0005: MOVLW FF
0006: MOVWF 20
000E: SLEEP
0007: BSF 07,1
0008: BCF 20,1
0009: MOVF 20,W
000A: BSF 03,5
000B: MOVWF 07
000C: BCF 03,5
000D: BSF 07,1
Notice in the second one, the compiler handles setting of the tris register. If output_high(PIN_C1) does not function the same as bit_set(*7,1) then you probably do not have the tris registers setup correctly. You can prove/disprove this by adding the #use fast_io(C) to you code and see if the output_high(PIN_C1) still functions. You should post more of you code (including the setting up of the tris registers) for more help.
If you are trying to save code space by using a for loop to set a few pins high, then take a look at this listing. It takes less code just to set them.
.................... for(i=0;1<4;i++)
0005: CLRF 21
.................... bit_set(*7,i);
0006: MOVLW 01
0007: MOVWF 77
0008: MOVF 21,W
0009: MOVWF 78
000A: BTFSC 03,2
000B: GOTO 010
000C: BCF 03,0
000D: RLF 77,F
000E: DECFSZ 78,F
000F: GOTO 00C
0010: MOVF 77,W
0011: IORWF 07,F
0012: INCF 21,F
0013: GOTO 006
.................... output_high(PIN_C0);
0014: BSF 07,0
0015: BSF 07,1
.................... output_high(PIN_C2);
0016: BSF 07,2
.................... output_high(PIN_C3);
0017: BSF 07,3
regards,
Mark
:=:=:=I modified my code, but it doesn't work at all.
:=:=:=Could you please whay the problem is?
:=:=:=Before)
:=:=:=output_high(PIN_C2);
:=:=:=output_high(PIN_C5);
:=:=:=output_high(PIN_B0);
:=:=:=output_high(PIN_B1); // all these worked well.
:=:=:=After)
:=:=:=int *LED[4];
:=:=:=int i;
:=:=:=LED[0] = 58; //actual bit address of PIN_C2
:=:=:=LED[1] = 61; //actual bit address of PIN_C5
:=:=:=LED[2] = 48; //actual bit address of PIN_B0
:=:=:=LED[3] = 49; //actual bit address of PIN_B1
:=:=:=for(i=0; i<4; i++)
:=:=:={ *LED[i] = 1; } // This doesn't work.
:=:=:=If my trial is fundermantally wrong, what will the way
:=:=:=to control each bits by relative addressing?
:=:=Start with the simple statement from the manual:
:=:="Arrays of SHORT, and pointers to SHORT are not permitted". The bits are shorts, and you are trying to use the numbers as pointer, so what you have will not work. You would end up setting the memory addresses 58,61,48 & 49 to 1...
:=:=There are several ways to get close to this, but none with the array quite as shown. One method, would be something like:
:=:=#define SET_BIT(x) = BIT_SET(*(x >> 3),x & 7)
:=:=Then:
:=:= SET_BIT(LED[i]);
:=:=should work.
:=:=This is based on the fact that the memory address of the port register is stored shifted left 3 bits in the numbers given by the normal defines, and the bit number, is the low three bits. Hence the 'SET_BIT' declaration, will remove the bottom three bits, and use this as the address of the register to be updated, then get the bit number from the low three bits, and do the actual 'set'.
:=:=Best Wishes
:=Hi, Thanks for the answer.
:=However, my problem has'n been solved yet.
:=To isolate other effects, I worte
:=BIT_SET(*(7 >> 3),1 & 7); //in order to turn on PORTC bit 1,
:= //but it didn't work, and
:=BIT_SET(*7, 1); // as manual recommends, but
:= // din't work either. Manual didn't talk about
:= // 3 bits shifting
:=Since
:=output_high(PIN_C1); always work, I believe others,
:=including my hardware and TRIS are OK.
:=The purpose of this is to use bit controls inside
:=for loop, without repeating output_high() function.
:=Is there any other way to do it?
:=Best regards
:=Dong
Original Post ID: 7510
dongseong
Re: Bit control
PostPosted: Sun Oct 06, 2002 10:38 pm     Reply with quote
Finally, bit_set() started to work, and I successfully
controled 8 LEDs on PORTC with for-loop as follows;
(I don't know the difference of previous and now...anyway)
for(i=0; i<8, i++)
{ bit_set(*7,i);
bit_clear(*7,i);
delay_ms(500); }
I appreciated your very detailed explanation.
Thanks so much...
Dong
:=:=:=:=Hello,
:=Take a look at the following listings. The first uses fast_io.
:=.................... #device PIC16F876
:=.................... #list
:=.................... #use fast_io(C)
:=.................... void main(void)
:=0004: CLRF 04
:=0007: SLEEP
:=.................... bit_set(*7,1);
:=0005: BSF 07,1
:=.................... output_high(PIN_C1);
:=0006: BSF 07,1
:=The next one does not use fast_io
:=0004: CLRF 04
:=0005: MOVLW FF
:=0006: MOVWF 20
:=000E: SLEEP
:=0007: BSF 07,1
:=0008: BCF 20,1
:=0009: MOVF 20,W
:=000A: BSF 03,5
:=000B: MOVWF 07
:=000C: BCF 03,5
:=000D: BSF 07,1
:=Notice in the second one, the compiler handles setting of the tris register. If output_high(PIN_C1) does not function the same as bit_set(*7,1) then you probably do not have the tris registers setup correctly. You can prove/disprove this by adding the #use fast_io(C) to you code and see if the output_high(PIN_C1) still functions. You should post more of you code (including the setting up of the tris registers) for more help.
:=If you are trying to save code space by using a for loop to set a few pins high, then take a look at this listing. It takes less code just to set them.
:=.................... for(i=0;1<4;i++)
:=0005: CLRF 21
:=.................... bit_set(*7,i);
:=0006: MOVLW 01
:=0007: MOVWF 77
:=0008: MOVF 21,W
:=0009: MOVWF 78
:=000A: BTFSC 03,2
:=000B: GOTO 010
:=000C: BCF 03,0
:=000D: RLF 77,F
:=000E: DECFSZ 78,F
:=000F: GOTO 00C
:=0010: MOVF 77,W
:=0011: IORWF 07,F
:=0012: INCF 21,F
:=0013: GOTO 006
:=.................... output_high(PIN_C0);
:=0014: BSF 07,0
:=0015: BSF 07,1
:=.................... output_high(PIN_C2);
:=0016: BSF 07,2
:=.................... output_high(PIN_C3);
:=0017: BSF 07,3
:=regards,
:=Mark
:=:=:=:=I modified my code, but it doesn't work at all.
:=:=:=:=Could you please whay the problem is?
:=:=:=:=Before)
:=:=:=:=output_high(PIN_C2);
:=:=:=:=output_high(PIN_C5);
:=:=:=:=output_high(PIN_B0);
:=:=:=:=output_high(PIN_B1); // all these worked well.
:=:=:=:=After)
:=:=:=:=int *LED[4];
:=:=:=:=int i;
:=:=:=:=LED[0] = 58; //actual bit address of PIN_C2
:=:=:=:=LED[1] = 61; //actual bit address of PIN_C5
:=:=:=:=LED[2] = 48; //actual bit address of PIN_B0
:=:=:=:=LED[3] = 49; //actual bit address of PIN_B1
:=:=:=:=for(i=0; i<4; i++)
:=:=:=:={ *LED[i] = 1; } // This doesn't work.
:=:=:=:=If my trial is fundermantally wrong, what will the way
:=:=:=:=to control each bits by relative addressing?
:=:=:=Start with the simple statement from the manual:
:=:=:="Arrays of SHORT, and pointers to SHORT are not permitted". The bits are shorts, and you are trying to use the numbers as pointer, so what you have will not work. You would end up setting the memory addresses 58,61,48 & 49 to 1...
:=:=:=There are several ways to get close to this, but none with the array quite as shown. One method, would be something like:
:=:=:=#define SET_BIT(x) = BIT_SET(*(x >> 3),x & 7)
:=:=:=Then:
:=:=:= SET_BIT(LED[i]);
:=:=:=should work.
:=:=:=This is based on the fact that the memory address of the port register is stored shifted left 3 bits in the numbers given by the normal defines, and the bit number, is the low three bits. Hence the 'SET_BIT' declaration, will remove the bottom three bits, and use this as the address of the register to be updated, then get the bit number from the low three bits, and do the actual 'set'.
:=:=:=Best Wishes
:=:=Hi, Thanks for the answer.
:=:=However, my problem has'n been solved yet.
:=:=To isolate other effects, I worte
:=:=BIT_SET(*(7 >> 3),1 & 7); //in order to turn on PORTC bit 1,
:=:= //but it didn't work, and
:=:=BIT_SET(*7, 1); // as manual recommends, but
:=:= // din't work either. Manual didn't talk about
:=:= // 3 bits shifting
:=:=Since
:=:=output_high(PIN_C1); always work, I believe others,
:=:=including my hardware and TRIS are OK.
:=:=The purpose of this is to use bit controls inside
:=:=for loop, without repeating output_high() function.
:=:=Is there any other way to do it?
:=:=Best regards
:=:=Dong
Original Post ID: 7512
R.J.Hamlett
Re: Bit control
PostPosted: Mon Oct 07, 2002 2:17 am     Reply with quote
:=:=:=Hello,
:=:=:=Before)
:=:=:=After)
:=:=:=int *LED[4];
:=:=:=int i;
:=:=Then:
:=:=should work.
:=:=Best Wishes
:=Since
:=Best regards
That won't work, because '7', is not the full address of bit C1. C1, is 57 from the defines. Try it with the values as given in your code allready (58, 59 etc.), and it will work. :-)
Original Post ID: 7515
