		| View previous topic :: View next topic   |
			JamesT Guest
				| i2c communication issues |
				 Posted: Wed Aug 28, 2002 11:36 am     |
				<font face="Courier New" size=-1>Hello all,
I am currently using two PIC 16c771 devices for a single master/slave i2c configuration.
Right now, I'm mainly concerned with writing two known good bytes of data to my slave and am using slave i2c hardware mode, not via software.
I have cut & pasted my code samples below.
I2C MASTER:
#INT_RTCC
  clk_isr()
         rb5=0;
         set_timer0(98);                  // interrupt 995 Hz
         set_adc_channel(0);              // select pin 1 as analog to digital channel
         delay_us(5);                     // delay required capacitor charge time
         value = read_adc();              // Take a sample of analog input
      switch (slave_driver){
      case 0:
            I2C_START();                     // generate i2c start condition
            if(!I2C_WRITE(0xA0))             // write to slave 0xA0 and expect a 0 for acknowledge
                  if(!I2C_WRITE(DATA1a))      // write first 8 bits
                        rb5=1;
                        I2C_WRITE(DATA2a);    // write second 8 bits
                        slave_driver = 1;    // move to next case
            i2c_stop();                      // generate i2c stop condition
      break; // end case 0
      case 1:
            if(!I2C_WRITE(0xB0))             // write to slave 0xB0 and expect a 0 for acknowledge
                  if(!I2C_WRITE(DATA1b))      // write first 8 bits
                        I2C_WRITE(DATA2b);    // write second 8 bits
                        slave_driver = 0;    // move to next case
      break; // end case 1
      i2c_reset();      // reset the i2c when done
I2C SLAVE:
#INT_SSP
void ssp_isr()
   {  // begin void
   switch(datacatcher)
         case ADDRESS:                 // begin case address
                addr=SSPBUF;           // read i2c buffer to a dummy variable, this clears the buffer
                                       // and prepares for next data byte
                datacatcher = byte1;     // transition for byte1 read
                if (addr != 0xA0)
                i2c_reset();           // reset SSP to continue to search for addres 0xA0
         case byte1:
               DATA1 = i2c_read();
               datacatcher = byte2;
         case byte2:
               DATA2 = i2c_read();
         i2c_reset();
      }  // end switch
   }  // end void
So far, my master is trying to address my slave, but unfortunately, there is no data transfer and I receive a !ACK and nothing from that point on.
Any help would be greatly appreciated.
Thanks!
Jim</font>
___________________________
	Original Post ID: 6679 |
			Mark
				| Re: i2c communication issues |
				 Posted: Wed Aug 28, 2002 1:56 pm     |
				Here is an example of some code that I did based on ACCESS.Bus protocol (it was actually modifed to include a checksum that is read back from the slave device).  I did not see where you are setting your address or the mode of operation.  The hardware will not receive any data if it is not addressed.  You should have something like this in your main()
  /* setup ABUS */
  SSPADD = Fixed_Address;
  SSPCON1 = (ABUS_SLAVE_MASK | ABUS_CLK_ENABLE | ABUS_MODE_SETUP);
  empty = SSPBUF;
  /* turn on access bus interrupt and set the abus address */
  PIR1bits.SSPIF=0;
  PIE1bits.SSPIE=1;
#INT_SSP
void ABus_Int(void)
  /* Make sure the buffer has not overflowed */
  if (SSPCON1bits.SSPOV)
    I2CStatus = SSPBUF;
    /* Clear the register */
    SSPCON1bits.SSPOV=0;
    I2CStatus = I2CIDLE;
    Wait_Time = 5;
    if (Rx_Msg.hdr.stat != PROCESS_OK)   /* don't recieve a byte              */
      ABUS_Rx_Byte();                    /* if we have a msg                  */
* NAME:        ABUS_Rx_Byte
* DESCRIPTION: Handles the Access.bus reception.
* PARAMETERS:  none
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void ABUS_Rx_Byte(void)
  static unsigned char rx_count = 0;             /* num of bytes received   */
  static unsigned char rx_msg_len = 0;           /* msg length              */
  static unsigned char checksum = 0;             /* message checksum (XOR)  */
  static unsigned char data = 0;                 /* data read from SSPBUF   */
  if (SSPSTATbits.P)
    Wait_Time = 1;
    I2C_Timeout = 0;
    /* were we addressed in read mode */
    if (SSPSTATbits.R_W)
      if (Rx_Msg.hdr.stat == CHECKSUM_OK)
        Rx_Msg.hdr.stat = PROCESS_OK;
        /* Load acknowledgement value */
        SSPBUF = MSGACK;
        SSPBUF = MSGNACK;
      /* Setup to allow data to be read from us */
      SSPCON1bits.CKP=1;
      I2CStatus = I2CSLAVETxING;
      I2C_Timeout = 25;
    /* See if we were addressed */
    else if (SSPSTATbits.BF)
      /* continue recieving bytes */
      /* process the first byte */
      if (!SSPSTATbits.D_A)
        /* Read the data */
        data = SSPBUF;
        Turn_On_Abus_LED();
        I2CStatus = I2CRxING;
        Rx_Msg.hdr.stat = INVALID_MSG;
        Rx_Msg.hdr.dest = data;
        rx_msg_len = 2;
        rx_count = 1;
        checksum = data;
        /* Read the data */
        data = SSPBUF;
        ++rx_count;                             /* keep track of how many bytes  */
        if (rx_count == 3)                      /* test for length of msg byte   */
          rx_msg_len = data & 0x7F;             /* set length counter, ignore MSB*/
          --rx_msg_len;
        if (rx_msg_len == -1)                   /* check for end of msg          */
          I2CStatus = I2CWAITING;
          if ((checksum ^ data) == 0)
            Rx_Msg.hdr.stat = CHECKSUM_OK;
        checksum ^= data;
        if (rx_count < sizeof(Rx_Msg.buf))
          Rx_Msg.buf[rx_count] = data;
      I2C_Timeout = 25;
Regards
Mark
:=I am currently using two PIC 16c771 devices for a single master/slave i2c configuration.
:=Right now, I'm mainly concerned with writing two known good bytes of data to my slave and am using slave i2c hardware mode, not via software.
:=I have cut & pasted my code samples below.
:=I2C MASTER:
:=#INT_RTCC
:=  clk_isr()
:=         rb5=0;
:=         set_timer0(98);                  // interrupt 995 Hz
:=         set_adc_channel(0);              // select pin 1 as analog to digital channel
:=         delay_us(5);                     // delay required capacitor charge time
:=         value = read_adc();              // Take a sample of analog input
:=      switch (slave_driver){
:=      case 0:
:=            I2C_START();                     // generate i2c start condition
:=            if(!I2C_WRITE(0xA0))             // write to slave 0xA0 and expect a 0 for acknowledge
:=                  if(!I2C_WRITE(DATA1a))      // write first 8 bits
:=                        rb5=1;
:=                        I2C_WRITE(DATA2a);    // write second 8 bits
:=                        slave_driver = 1;    // move to next case
:=            i2c_stop();                      // generate i2c stop condition
:=      break; // end case 0
:=      case 1:
:=            if(!I2C_WRITE(0xB0))             // write to slave 0xB0 and expect a 0 for acknowledge
:=                  if(!I2C_WRITE(DATA1b))      // write first 8 bits
:=                        I2C_WRITE(DATA2b);    // write second 8 bits
:=                        slave_driver = 0;    // move to next case
:=      break; // end case 1
:=      i2c_reset();      // reset the i2c when done
:=I2C SLAVE:
:=#INT_SSP
:=void ssp_isr()
:=   {  // begin void
:=   switch(datacatcher)
:=         case ADDRESS:                 // begin case address
:=                addr=SSPBUF;           // read i2c buffer to a dummy variable, this clears the buffer
:=                                       // and prepares for next data byte
:=                datacatcher = byte1;     // transition for byte1 read
:=                if (addr != 0xA0)
:=                i2c_reset();           // reset SSP to continue to search for addres 0xA0
:=         break;
:=         case byte1:
:=               DATA1 = i2c_read();
:=               datacatcher = byte2;
:=         break;
:=         case byte2:
:=               DATA2 = i2c_read();
:=         break;
:=         i2c_reset();
:=      }  // end switch
:=   }  // end void
:=So far, my master is trying to address my slave, but unfortunately, there is no data transfer and I receive a !ACK and nothing from that point on.
:=Any help would be greatly appreciated.
:=Thanks!
:=Jim</font>
	Original Post ID: 6689 |
			JamesT Guest
				 Posted: Thu Aug 29, 2002 10:56 am     |
				Mark,
Thank you for the information, and I will try to implement snippettes of your work into my code.  Actually, my code was pretty much just the ISRs.  So far, I've pretty much narrowed it down to a slave side issue.  I've cut/pasted my entire slave code.  I agree with you, nothing will occur unless the hardware is addressed.
Here is my slave code:
#include <16c771.h>
#fuses BROWNOUT,HS,NOWDT,MCLR
#use delay(clock = 12000000)
#use I2C(slave, sda=pin_b4, scl=pin_b2,address=0xA0,noforce_sw,restart_wdt)
// memory map: portA
#byte PORTA = 0x05
   #bit  ra0 = 0x05.0
   #bit  ra1 = 0x05.1
   #bit  ra2 = 0x05.2
   #bit  ra3 = 0x05.3
   #bit  ra4 = 0x05.4
   #bit  ra5 = 0x05.5
   #bit  ra6 = 0x05.6
   #bit  ra7 = 0x05.7
// memory map: portB
#byte PORTA = 0x06
   #bit  rb0 = 0x06.0
   #bit  rb1 = 0x06.1
   #bit  rb2 = 0x06.2
   #bit  rb3 = 0x06.3
   #bit  rb4 = 0x06.4
   #bit  rb5 = 0x06.5
   #bit  rb6 = 0x06.6
   #bit  rb7 = 0x06.7
// A/D setup
//#byte AD
// memory map: i2c operation (SSP)
// i2c control register1
#byte SSPCON = 0x14
      #bit SSPM0 = 0x14.0
      #bit SSPM1 = 0x14.1
      #bit SSPM2 = 0x14.2
      #bit SSPM3 = 0x14.3
      #bit CKP   = 0x14.4           // clock polarity
      #bit SSPEN = 0x14.5           // i2c enable
      #bit SSPOV = 0x14.6           // i2c overflow bit
      #bit WCOL  = 0x14.7           // wr collision detect bit
// i2c control register2
#byte SSPCON2 = 0x91
      #bit SEN = 0x91.0
      #bit RSEN = 0x91.1
      #bit PEN = 0x91.2
      #bit RCEN = 0x91.3
      #bit ACKEN = 0x91.4           // ACK enable bit
      #bit ACKDT = 0x91.5           // ACK data bit
      #bit ACKSTAT = 0x91.6         // ACK status bit
      #bit GCEN = 0x91.7
// i2c status register
#byte SSPSTAT = 0x94
      #bit BF = 0x94.0              // buffer full flag
      #bit RW = 0x94.2              // read_write bit
      #bit CKE = 0x94.6             //
      #bit SMP = 0x94.7             // sample phase bit
// i2c address register
#byte SSPADD = 0x93
// SSP receive buffer/transmit register
#byte SSPBUF = 0x13
// i2c shift register
// #byte SSPSR = 0x??               // not readily accessible
// control bits
#bit SSPIF = 0x0C.3                 // clear the SSP interrupt flag
#bit SSPIE = 0x8C.3                 // enable the SSP interrupt
#bit PEIE = 0x8b.6                  // enable ALL periph intrpt
//ANALOG TO DIGITAL SETUP
#byte ADref = 0x9F                  // reference setup
#byte ADsel = 0x1F                  // a/d setup
#byte ANsel = 0x9D                  // PORTA ANALOG SELECT DI/O or ANALOG IN
#byte ADout = 0x9E                  // UPPER PORTION OF A/D 12 BIT OUTPUT
#bit  ADon = 0x1F.2                 // INITIATE A/D BIT
// global variables
int addr;                        //store incoming address
long DATA1;                      //i2c data
long DATA2;                      //i2c data
long value;                      //temp variable
long adc_value;                  //temp variable
long Incoming1;                  //i2c temp
long Incoming2;                  //i2c temp
int i2cfail;                     //i2c hang counter
int datacatcher = 0;               //i2c data flow variable
void i2c_reset(void);            //function prototype for i2c reset
// i2c states
#define address   0
#define byte1     1
#define byte2     2
// initializes i2c bus
void init_i2c()
      SSPCON = 0x36;       //enable i2c slave mode & 7bit addr
      BF = 0;              //RESET buffer
      SSPOV = 0;           //RESET OVERFLOW BIT
      SSPADD = 0xA0;       //set i2c address
      SSPIE = 1;           //enable ssp interrupts
      SSPIF = 0;           //reset interrupt flag
      PEIE = 1;            //enable all peripheral interrupts
      SSPEN = 1;           //enable i2c
      //SMP = 0;           //slew rate control 400khz
// i2c reset routine, courtesy: Justin S.
void i2c_reset()
      SSPEN = 0;           //reset i2c enable
      SSPOV = 0;           //reset overflow bit
      BF = 0;              //reset buffer full
      i2cfail = 0;         //reset i2c hang counter
// clock interupt service routine, courtesy: Justin S.
#INT_RTCC
void clock_isr()
   set_timer0(98);         //interrupt 995 Hz
   set_adc_channel(0);     //select pin 1 as A/D channel
   delay_us(5);            // delay required cap charge time
   adc_value = read_adc();     // Take a sample of analog input
       while(ADon)             //Wait for req. samples to fill register
            //wait for a/d complete
   i2cfail = i2cfail+1;             //increment i2c counter
   if (i2cfail>2)                   //is i2c bus hanging?
      {                             //yes
      i2c_reset();                  //resets i2c
    //enter transfer function
#INT_SSP
void ssp_isr()
   {  // begin ssp_isr
   switch(datacatcher)
         case address:                 // begin case address
                                       // dummy variable
                                       // this clears the buf
                                       // data byte
                datacatcher = byte1;   // switch to byte1 read
                if (addr != 0xA0)
         case byte1:
            if (i2c_poll() == TRUE)
               DATA1 = SSPBUF;         // clear SSP and stuff
                                       // stuff variable
               //CKP = 1;              // clk polarity (omit)
               DATA1 = i2c_read(1);    // read from variable
               datacatcher = byte2;    // next state: byte2
            else datacatcher = address;
         case byte2:
               DATA2 = SSPBUF;         // clear SSP and stuff
                                       // variable
               DATA2 = i2c_read(0);    // read from variable
               datacatcher = address;  // take it from the top
         i2c_reset();
      }  // end switch
      SSPIF = 0;             // reset the i2c interrupt
      //SSPOV = 0;           // reset the over-flow bit
      BF = 0;                // reset the buffer full bit
      i2cfail = 0;           // reset the hang counter
   }  // end ssp_isr
   {  // begin main
      set_tris_a(0xFF);          //set port a as all inputs
      set_tris_b(0x14);          //set port b pins19 & 11
                                 //as inputs for i2c/all
                                 //others are outputs
      set_rtcc(0);                   //Clock = 12,000,000Hz
      setup_counters(rtcc_internal,
                     rtcc_div_32);   //20,000,000/4/32 = 156,250
      init_i2c();                         //initialize i2c
      enable_interrupts(INT_RTCC);        //flag timer 0 int
      enable_interrupts(INT_SSP);         //flag i2c interrupts
      enable_interrupts(GLOBAL);          //enable all flagged
                                          //interrupts
   }  // end main
By the way, this will eventually be set for A/D conversions, but for the sake of testibility for right now, they have been omitted.  Right now, the problem that I'm having is that it seems as if my slave is holding the SCL line low after my first byte of data is received.  For some reason, it seems as if the SSPBUF is waiting to receive the second byte, and after a while the slave then allows the SCL to be generated by the master.  From that point on the second byte is received.
In all honesty, I'm not all too sure about my code and whether or not I am using the i2c hardware functions correctly.  It was my impression that the i2c_poll, if returned as a "true" would then allow me to read directly from the SSPBUF, which is what I did...or at least I think I did...
Any input? =\
Once again, thank you!
Jim
	Original Post ID: 6726 |
			Mark
				 Posted: Thu Aug 29, 2002 8:23 pm     |
				<pre>
For starters, don't use CCS's built in functions.  You are using a mixture of both in your code.  Here are some problems as I see it:
1. The BF bit is read only.  To clear it, you must read the SSPBUF.
2. The i2c_read() function.  What does this do?  The manual says that it will wait for a byte to come in?  Does it check for the BF bit and if set then return immediately else sit and wait forever?  I really can't tell from the manual.  What should this function do, this
  retval = SSPBUF
3. Never wait in an isr.  If you are only using one channel, then there is no need to keep setting it.  You only need to start the conversion and either poll for the completion in your main or use an interrupt.
See below for changes that I have made.  Please note that you might have to adjust the delays based on your frequency.  The ones given were used on a device @ 20MHz.
Here are some notes from one of my designs.  Refer to the datasheet for more information.  Also, some of the #defines need values.
*             Analog-to-Digital Converter (ADC) NOTES:
*  The A/D conversion clock (TAD) is generated from the oscillator
*  via a programmable divider.  The divider choices are 2, 8, or 32.
*  The minimum allowable TAD period is 1.6uS for the PIC16C76, so
*  the divider must be chosen carefully.  Given a 20MHz oscillator,
*  choosing a divider of 32 would result in a TAD period of 1.6u,
*  and a CONVERSION TIME of 16uS.
*  Three time delays must be observed:
*  SAMPLING TIME:  The time required for the sample & hold (S&H)
*    circuit to acquire the new voltage level after the analog input
*    channel is changed. The minimum required sampling time, given
*    a source impedance of 10K ohms and an ambient temp of 50 deg C,
*    (worst case conditions) is 12uS.  At the same temp with a zero
*    ohm source impedance, the minimum sampling time works out to be
*    8.8uS. See formula in Microchip Microcontroller Data Book.
*  CONVERSION TIME:  The time required for the ADC to calculate the
*    digital value corresponding to the analog input after the
*    conversion is started.  Sampling time = 10 x TAD period.
*  POST-CONVERSION TIME: After a conversion has been completed, 2
*    TAD cycles must elapse before sampling can begin again.  During
*    this time the S&H capacitor is not connected to the selected
*    ADC input channel.
*  The delays associated with this design are:
*    SAMPLING TIME:    12uS
*    CONVERSION TIME:  16uS
*    POST-CONVERSION:  3.2uS
*      (1 instruction cycle time = 200ns)
If you need any more help, let me know.  I do alot of work with i2c.  Some engineer thought it was a good means of communicating between devices on a small network!
Here is a link to one of our systems.  The big cabinet in the picture can have as many as 18 devices on the i2c bus in a multi-master mode.
 <a href="http://www.lithonia.com/controls/SynergyOnlineBrochure/SystemArchitecture.pdf" TARGET="_blank">http://www.lithonia.com/controls/SynergyOnlineBrochure/SystemArchitecture.pdf</a>
Regards
Mark
:=Mark,
:=Thank you for the information, and I will try to implement snippettes of your work into my code.  Actually, my code was pretty much just the ISRs.  So far, I've pretty much narrowed it down to a slave side issue.  I've cut/pasted my entire slave code.  I agree with you, nothing will occur unless the hardware is addressed.
:=Here is my slave code:
:=#include <16c771.h>
:=#fuses BROWNOUT,HS,NOWDT,MCLR
:=#use delay(clock = 12000000)
Don't need this - we won't use CCS.
:=//#use I2C(slave, sda=pin_b4, scl=pin_b2,address=0xA0,noforce_sw,restart_wdt)
:=// memory map: portA
:=#byte PORTA = 0x05
:=   #bit  ra0 = 0x05.0
:=   #bit  ra1 = 0x05.1
:=   #bit  ra2 = 0x05.2
:=   #bit  ra3 = 0x05.3
:=   #bit  ra4 = 0x05.4
:=   #bit  ra5 = 0x05.5
:=   #bit  ra6 = 0x05.6
:=   #bit  ra7 = 0x05.7
:=// memory map: portB
:=#byte PORTA = 0x06
:=   #bit  rb0 = 0x06.0
:=   #bit  rb1 = 0x06.1
:=   #bit  rb2 = 0x06.2
:=   #bit  rb3 = 0x06.3
:=   #bit  rb4 = 0x06.4
:=   #bit  rb5 = 0x06.5
:=   #bit  rb6 = 0x06.6
:=   #bit  rb7 = 0x06.7
:=// A/D setup
:=//#byte AD
:=// memory map: i2c operation (SSP)
:=// i2c control register1
:=#byte SSPCON = 0x14
:=      #bit SSPM0 = 0x14.0
:=      #bit SSPM1 = 0x14.1
:=      #bit SSPM2 = 0x14.2
:=      #bit SSPM3 = 0x14.3
:=      #bit CKP   = 0x14.4           // clock polarity
:=      #bit SSPEN = 0x14.5           // i2c enable
:=      #bit SSPOV = 0x14.6           // i2c overflow bit
:=      #bit WCOL  = 0x14.7           // wr collision detect bit
:=// i2c control register2
:=#byte SSPCON2 = 0x91
:=      #bit SEN = 0x91.0
:=      #bit RSEN = 0x91.1
:=      #bit PEN = 0x91.2
:=      #bit RCEN = 0x91.3
:=      #bit ACKEN = 0x91.4           // ACK enable bit
:=      #bit ACKDT = 0x91.5           // ACK data bit
:=      #bit ACKSTAT = 0x91.6         // ACK status bit
:=      #bit GCEN = 0x91.7
:=// i2c status register
:=#byte SSPSTAT = 0x94
:=      #bit BF = 0x94.0              // buffer full flag
:=      #bit RW = 0x94.2              // read_write bit
:=      #bit CKE = 0x94.6             //
:=      #bit SMP = 0x94.7             // sample phase bit
      #bit S = 0x94.?               // start condition
      #bit P = 0x94.?               // stop condition
      #bit DA = 0x94.?              // data or address
:=// i2c address register
:=#byte SSPADD = 0x93
:=// SSP receive buffer/transmit register
:=#byte SSPBUF = 0x13
:=// i2c shift register
:=// #byte SSPSR = 0x??               // not readily accessible
:=// control bits
:=#bit SSPIF = 0x0C.3                 // clear the SSP interrupt flag
:=#bit SSPIE = 0x8C.3                 // enable the SSP interrupt
:=#bit PEIE = 0x8b.6                  // enable ALL periph intrpt
#byte ADRES  = 0x??
#byte ADCON0 = 0x??
#byte ADCON1 = 0x??
:=//ANALOG TO DIGITAL SETUP
:=#byte ADref = 0x9F                  // reference setup
:=#byte ADsel = 0x1F                  // a/d setup
:=#byte ANsel = 0x9D                  // PORTA ANALOG SELECT DI/O or ANALOG IN
:=#byte ADout = 0x9E                  // UPPER PORTION OF A/D 12 BIT OUTPUT
:=#bit  ADon = 0x1F.2                 // INITIATE A/D BIT
:=// global variables
:=int addr;                        //store incoming address
:=long DATA1;                      //i2c data
:=long DATA2;                      //i2c data
:=long value;                      //temp variable
:=long adc_value;                  //temp variable
:=long Incoming1;                  //i2c temp
:=long Incoming2;                  //i2c temp
:=int i2cfail;                     //i2c hang counter
:=int datacatcher = 0;               //i2c data flow variable
:=void i2c_reset(void);            //function prototype for i2c reset
:=// i2c states
:=#define address   0
:=#define byte1     1
:=#define byte2     2
#define ALL_ANALOG         0x00
#define ADC_CLOCK_DIV_32   0x81
:=// initializes i2c bus
:=void init_i2c()
  int dummy;
:=      SSPCON = 0x36;       //enable i2c slave mode & 7bit addr
// BF is Read only!!!
//      BF = 0;              //RESET buffer
  dummy = SSPBUF;              //RESET buffer
:=      SSPOV = 0;           //RESET OVERFLOW BIT
:=      SSPADD = 0xA0;       //set i2c address
//I would clear the flag before I enable the int
:=      PEIE = 1;            //enable all peripheral interrupts
:=      SSPEN = 1;           //enable i2c
:=      //SMP = 0;           //slew rate control 400khz
:=// i2c reset routine, courtesy: Justin S.
:=void i2c_reset()
  int dummy;
:=      SSPEN = 0;           //reset i2c enable
:=      SSPOV = 0;           //reset overflow bit
Read only!!!
//      BF = 0;              //reset buffer full
:=      i2cfail = 0;         //reset i2c hang counter
:=// clock interupt service routine, courtesy: Justin S.
:=#INT_RTCC
:=void clock_isr()
:=   set_timer0(98);         //interrupt 995 Hz
// moved A/D to main
//   set_adc_channel(0);     //select pin 1 as A/D channel
//   delay_us(5);            // delay required cap charge time
//   adc_value = read_adc();     // Take a sample of analog input
//       while(ADon)             //Wait for req. samples to fill register
//            //wait for a/d complete
// did not implement anything here for the reset.
// you can add it back if you want but you should only hang up if
// the device is accessed in read mode and you don't set the CKE back high
//   i2cfail = i2cfail+1;             //increment i2c counter
//   if (i2cfail>2)                   //is i2c bus hanging?
//      {                             //yes
/      i2c_reset();                  //resets i2c
:=    //enter transfer function
:=#INT_SSP
:=void ssp_isr()
:=   {  // begin ssp_isr
  char dummy;
  // Make sure the buffer has not overflowed
  if (SSPOV)
    // Clear the register
    dummy = SSPBUF;
    SSPOV=0;
    return();
  //Look for a stop
  if (P)
    return();
    // were we addressed in read mode
    if (RW)
      //Note that the code below is how you would send back a value
      //You could check the data written to you below and set a flag
      //or something to know what to send back
      return();
      // Load our response
      SSPBUF = adc_value;
      // Stop stretching the clock
      CKE=1;
    // Do we have any data
    else if (BF)
      // See if we were addressed
      if (!D_A)
        // Read the address
        // Note that it is really not necessary to check the address
        // Since you would not receive any data if the address did not
        // Match your SSPADDR!
        data = SSPBUF;
        // Read the data
        data = SSPBUF;
//Note that I did not clear the SSPIF.  The compiler does this for you.
//Also you cannot clear the BF bit.  It is done when you read the SSPBUF
//I am not sure what your intention here is, but I think you are planning to
//Read an ADC value from this slave device.
:=   }  // end ssp_isr
:=void main(void)
:=   {  // begin main
char ADC_Chan_Num = 0;
:=      set_tris_a(0xFF);          //set port a as all inputs
// Note for Channel 0 you could just use
//ADCON0 = ADC_CLOCK_DIV_32;
ADCON0 = (ADC_CLOCK_DIV_32 | (ADC_Chan_Num << 3));
ADCON1 = ALL_ANALOG;
:=      set_tris_b(0x14);          //set port b pins19 & 11
:=                                 //as inputs for i2c/all
:=                                 //others are outputs
:=      set_rtcc(0);                   //Clock = 12,000,000Hz
:=      setup_counters(rtcc_internal,
:=                     rtcc_div_32);   //20,000,000/4/32 = 156,250
:=      init_i2c();                         //initialize i2c
:=      enable_interrupts(INT_RTCC);        //flag timer 0 int
//Not needed - you did this in init_i2c
//      enable_interrupts(INT_SSP);         //flag i2c interrupts
:=      enable_interrupts(GLOBAL);          //enable all flagged
:=                                          //interrupts
  delay_us(12);            // delay required cap charge time
  // Start the ADC conversion
  ADon = 1;
  // You need and endless loop here
  if (!(ADon))
    adc_value=ADRES;
    //Post conversion time
    delay_us(3);
    //Start the next conversion
    ADon = 1;
:=   }  // end main
:=By the way, this will eventually be set for A/D conversions, but for the sake of testibility for right now, they have been omitted.  Right now, the problem that I'm having is that it seems as if my slave is holding the SCL line low after my first byte of data is received.  For some reason, it seems as if the SSPBUF is waiting to receive the second byte, and after a while the slave then allows the SCL to be generated by the master.  From that point on the second byte is received.
:=In all honesty, I'm not all too sure about my code and whether or not I am using the i2c hardware functions correctly.  It was my impression that the i2c_poll, if returned as a "true" would then allow me to read directly from the SSPBUF, which is what I did...or at least I think I did...
:=Any input? =\
:=Once again, thank you!
:=Jim
	Original Post ID: 6732 |
			JamesT Guest
				 Posted: Fri Sep 06, 2002 10:24 am     |
				:=<pre>
:=For starters, don't use CCS's built in functions.  You are using a mixture of both in your code.  Here are some problems as I see it:
:=1. The BF bit is read only.  To clear it, you must read the SSPBUF.
:=2. The i2c_read() function.  What does this do?  The manual says that it will wait for a byte to come in?  Does it check for the BF bit and if set then return immediately else sit and wait forever?  I really can't tell from the manual.  What should this function do, this
:=  retval = SSPBUF
:=3. Never wait in an isr.  If you are only using one channel, then there is no need to keep setting it.  You only need to start the conversion and either poll for the completion in your main or use an interrupt.
:=See below for changes that I have made.  Please note that you might have to adjust the delays based on your frequency.  The ones given were used on a device @ 20MHz.
:=Here are some notes from one of my designs.  Refer to the datasheet for more information.  Also, some of the #defines need values.
:=*             Analog-to-Digital Converter (ADC) NOTES:
:=*  The A/D conversion clock (TAD) is generated from the oscillator
:=*  via a programmable divider.  The divider choices are 2, 8, or 32.
:=*  The minimum allowable TAD period is 1.6uS for the PIC16C76, so
:=*  the divider must be chosen carefully.  Given a 20MHz oscillator,
:=*  choosing a divider of 32 would result in a TAD period of 1.6u,
:=*  and a CONVERSION TIME of 16uS.
:=*  Three time delays must be observed:
:=*  SAMPLING TIME:  The time required for the sample & hold (S&H)
:=*    circuit to acquire the new voltage level after the analog input
:=*    channel is changed. The minimum required sampling time, given
:=*    a source impedance of 10K ohms and an ambient temp of 50 deg C,
:=*    (worst case conditions) is 12uS.  At the same temp with a zero
:=*    ohm source impedance, the minimum sampling time works out to be
:=*    8.8uS. See formula in Microchip Microcontroller Data Book.
:=*  CONVERSION TIME:  The time required for the ADC to calculate the
:=*    digital value corresponding to the analog input after the
:=*    conversion is started.  Sampling time = 10 x TAD period.
:=*  POST-CONVERSION TIME: After a conversion has been completed, 2
:=*    TAD cycles must elapse before sampling can begin again.  During
:=*    this time the S&H capacitor is not connected to the selected
:=*    ADC input channel.
:=*  The delays associated with this design are:
:=*    SAMPLING TIME:    12uS
:=*    CONVERSION TIME:  16uS
:=*    POST-CONVERSION:  3.2uS
:=*      (1 instruction cycle time = 200ns)
:=If you need any more help, let me know.  I do alot of work with i2c.  Some engineer thought it was a good means of communicating between devices on a small network!
:=Here is a link to one of our systems.  The big cabinet in the picture can have as many as 18 devices on the i2c bus in a multi-master mode.
:= <a href="http://www.lithonia.com/controls/SynergyOnlineBrochure/SystemArchitecture.pdf" TARGET="_blank"> <a href="http://www.lithonia.com/controls/SynergyOnlineBrochure/SystemArchitecture.pdf" TARGET="_blank">http://www.lithonia.com/controls/SynergyOnlineBrochure/SystemArchitecture.pdf</a></a>
:=Regards
:=Mark
:=:=Mark,
:=:=Thank you for the information, and I will try to implement snippettes of your work into my code.  Actually, my code was pretty much just the ISRs.  So far, I've pretty much narrowed it down to a slave side issue.  I've cut/pasted my entire slave code.  I agree with you, nothing will occur unless the hardware is addressed.
:=:=Here is my slave code:
:=:=#include <16c771.h>
:=:=#fuses BROWNOUT,HS,NOWDT,MCLR
:=:=#use delay(clock = 12000000)
:=Don't need this - we won't use CCS.
:=:=//#use I2C(slave, sda=pin_b4, scl=pin_b2,address=0xA0,noforce_sw,restart_wdt)
:=:=// memory map: portA
:=:=#byte PORTA = 0x05
:=:=   #bit  ra0 = 0x05.0
:=:=   #bit  ra1 = 0x05.1
:=:=   #bit  ra2 = 0x05.2
:=:=   #bit  ra3 = 0x05.3
:=:=   #bit  ra4 = 0x05.4
:=:=   #bit  ra5 = 0x05.5
:=:=   #bit  ra6 = 0x05.6
:=:=   #bit  ra7 = 0x05.7
:=:=// memory map: portB
:=:=#byte PORTA = 0x06
:=:=   #bit  rb0 = 0x06.0
:=:=   #bit  rb1 = 0x06.1
:=:=   #bit  rb2 = 0x06.2
:=:=   #bit  rb3 = 0x06.3
:=:=   #bit  rb4 = 0x06.4
:=:=   #bit  rb5 = 0x06.5
:=:=   #bit  rb6 = 0x06.6
:=:=   #bit  rb7 = 0x06.7
:=:=// A/D setup
:=:=//#byte AD
:=:=// memory map: i2c operation (SSP)
:=:=// i2c control register1
:=:=#byte SSPCON = 0x14
:=:=      #bit SSPM0 = 0x14.0
:=:=      #bit SSPM1 = 0x14.1
:=:=      #bit SSPM2 = 0x14.2
:=:=      #bit SSPM3 = 0x14.3
:=:=      #bit CKP   = 0x14.4           // clock polarity
:=:=      #bit SSPEN = 0x14.5           // i2c enable
:=:=      #bit SSPOV = 0x14.6           // i2c overflow bit
:=:=      #bit WCOL  = 0x14.7           // wr collision detect bit
:=:=// i2c control register2
:=:=#byte SSPCON2 = 0x91
:=:=      #bit SEN = 0x91.0
:=:=      #bit RSEN = 0x91.1
:=:=      #bit PEN = 0x91.2
:=:=      #bit RCEN = 0x91.3
:=:=      #bit ACKEN = 0x91.4           // ACK enable bit
:=:=      #bit ACKDT = 0x91.5           // ACK data bit
:=:=      #bit ACKSTAT = 0x91.6         // ACK status bit
:=:=      #bit GCEN = 0x91.7
:=:=// i2c status register
:=:=#byte SSPSTAT = 0x94
:=:=      #bit BF = 0x94.0              // buffer full flag
:=:=      #bit RW = 0x94.2              // read_write bit
:=:=      #bit CKE = 0x94.6             //
:=:=      #bit SMP = 0x94.7             // sample phase bit
:=      #bit S = 0x94.?               // start condition
:=      #bit P = 0x94.?               // stop condition
:=      #bit DA = 0x94.?              // data or address
:=:=// i2c address register
:=:=#byte SSPADD = 0x93
:=:=// SSP receive buffer/transmit register
:=:=#byte SSPBUF = 0x13
:=:=// i2c shift register
:=:=// #byte SSPSR = 0x??               // not readily accessible
:=:=// control bits
:=:=#bit SSPIF = 0x0C.3                 // clear the SSP interrupt flag
:=:=#bit SSPIE = 0x8C.3                 // enable the SSP interrupt
:=:=#bit PEIE = 0x8b.6                  // enable ALL periph intrpt
:=#byte ADRES  = 0x??
:=#byte ADCON0 = 0x??
:=#byte ADCON1 = 0x??
:=:=//ANALOG TO DIGITAL SETUP
:=:=#byte ADref = 0x9F                  // reference setup
:=:=#byte ADsel = 0x1F                  // a/d setup
:=:=#byte ANsel = 0x9D                  // PORTA ANALOG SELECT DI/O or ANALOG IN
:=:=#byte ADout = 0x9E                  // UPPER PORTION OF A/D 12 BIT OUTPUT
:=:=#bit  ADon = 0x1F.2                 // INITIATE A/D BIT
:=:=// global variables
:=:=int addr;                        //store incoming address
:=:=long DATA1;                      //i2c data
:=:=long DATA2;                      //i2c data
:=:=long value;                      //temp variable
:=:=long adc_value;                  //temp variable
:=:=long Incoming1;                  //i2c temp
:=:=long Incoming2;                  //i2c temp
:=:=int i2cfail;                     //i2c hang counter
:=:=int datacatcher = 0;               //i2c data flow variable
:=:=void i2c_reset(void);            //function prototype for i2c reset
:=:=// i2c states
:=:=#define address   0
:=:=#define byte1     1
:=:=#define byte2     2
:=#define ALL_ANALOG         0x00
:=#define ADC_CLOCK_DIV_32   0x81
:=:=// initializes i2c bus
:=:=void init_i2c()
:=  int dummy;
:=:=      SSPCON = 0x36;       //enable i2c slave mode & 7bit addr
:=// BF is Read only!!!
:=//      BF = 0;              //RESET buffer
:=  dummy = SSPBUF;              //RESET buffer
:=:=      SSPOV = 0;           //RESET OVERFLOW BIT
:=:=      SSPADD = 0xA0;       //set i2c address
:=//I would clear the flag before I enable the int
:=      SSPIF = 0;           //reset interrupt flag
:=      SSPIE = 1;           //enable ssp interrupts
:=:=      PEIE = 1;            //enable all peripheral interrupts
:=:=      SSPEN = 1;           //enable i2c
:=:=      //SMP = 0;           //slew rate control 400khz
:=:=// i2c reset routine, courtesy: Justin S.
:=:=void i2c_reset()
:=  int dummy;
:=:=      SSPEN = 0;           //reset i2c enable
:=:=      SSPOV = 0;           //reset overflow bit
:=Read only!!!
:=//      BF = 0;              //reset buffer full
:=:=      i2cfail = 0;         //reset i2c hang counter
:=:=// clock interupt service routine, courtesy: Justin S.
:=:=#INT_RTCC
:=:=void clock_isr()
:=:=   set_timer0(98);         //interrupt 995 Hz
:=// moved A/D to main
:=//   set_adc_channel(0);     //select pin 1 as A/D channel
:=//   delay_us(5);            // delay required cap charge time
:=//   adc_value = read_adc();     // Take a sample of analog input
:=//       while(ADon)             //Wait for req. samples to fill register
:=//            //wait for a/d complete
:=// did not implement anything here for the reset.
:=// you can add it back if you want but you should only hang up if
:=// the device is accessed in read mode and you don't set the CKE back high
:=//   i2cfail = i2cfail+1;             //increment i2c counter
:=//   if (i2cfail>2)                   //is i2c bus hanging?
:=//      {                             //yes
:=/      i2c_reset();                  //resets i2c
:=:=    //enter transfer function
:=:=#INT_SSP
:=:=void ssp_isr()
:=:=   {  // begin ssp_isr
:=  char dummy;
:=  // Make sure the buffer has not overflowed
:=  if (SSPOV)
:=    // Clear the register
:=    dummy = SSPBUF;
:=    SSPOV=0;
:=    return();
:=  //Look for a stop
:=  if (P)
:=    return();
:=  else
:=    // were we addressed in read mode
:=    if (RW)
:=      //Note that the code below is how you would send back a value
:=      //You could check the data written to you below and set a flag
:=      //or something to know what to send back
:=      return();
:=      // Load our response
:=      SSPBUF = adc_value;
:=      // Stop stretching the clock
:=      CKE=1;
:=    // Do we have any data
:=    else if (BF)
:=      // See if we were addressed
:=      if (!D_A)
:=        // Read the address
:=        // Note that it is really not necessary to check the address
:=        // Since you would not receive any data if the address did not
:=        // Match your SSPADDR!
:=        data = SSPBUF;
:=      else
:=        // Read the data
:=        data = SSPBUF;
:=//Note that I did not clear the SSPIF.  The compiler does this for you.
:=//Also you cannot clear the BF bit.  It is done when you read the SSPBUF
:=//I am not sure what your intention here is, but I think you are planning to
:=//Read an ADC value from this slave device.
:=:=   }  // end ssp_isr
:=:=void main(void)
:=:=   {  // begin main
:=char ADC_Chan_Num = 0;
:=:=      set_tris_a(0xFF);          //set port a as all inputs
:=// Note for Channel 0 you could just use
:=//ADCON0 = ADC_CLOCK_DIV_32;
:=ADCON0 = (ADC_CLOCK_DIV_32 | (ADC_Chan_Num << 3));
:=ADCON1 = ALL_ANALOG;
:=:=      set_tris_b(0x14);          //set port b pins19 & 11
:=:=                                 //as inputs for i2c/all
:=:=                                 //others are outputs
:=:=      set_rtcc(0);                   //Clock = 12,000,000Hz
:=:=      setup_counters(rtcc_internal,
:=:=                     rtcc_div_32);   //20,000,000/4/32 = 156,250
:=:=      init_i2c();                         //initialize i2c
:=:=      enable_interrupts(INT_RTCC);        //flag timer 0 int
:=//Not needed - you did this in init_i2c
:=//      enable_interrupts(INT_SSP);         //flag i2c interrupts
:=:=      enable_interrupts(GLOBAL);          //enable all flagged
:=:=                                          //interrupts
:=  delay_us(12);            // delay required cap charge time
:=  // Start the ADC conversion
:=  ADon = 1;
:=  // You need and endless loop here
:=  while(1)
:=  if (!(ADon))
:=    adc_value=ADRES;
:=    //Post conversion time
:=    delay_us(3);
:=    //Start the next conversion
:=    ADon = 1;
:=:=   }  // end main
:=:=By the way, this will eventually be set for A/D conversions, but for the sake of testibility for right now, they have been omitted.  Right now, the problem that I'm having is that it seems as if my slave is holding the SCL line low after my first byte of data is received.  For some reason, it seems as if the SSPBUF is waiting to receive the second byte, and after a while the slave then allows the SCL to be generated by the master.  From that point on the second byte is received.
:=:=In all honesty, I'm not all too sure about my code and whether or not I am using the i2c hardware functions correctly.  It was my impression that the i2c_poll, if returned as a "true" would then allow me to read directly from the SSPBUF, which is what I did...or at least I think I did...
:=:=Any input? =\
:=:=Once again, thank you!
:=:=Jim
Mark,
I apologize for the delay as my labor day weekend was longer than I expected.  Trust me, it was definately a good thing!
I've decided to dump the CCS built in functions for my slave.  For some reason, they work like a charm with my master, but not for my slaves...go figure.  You are right, dumping the functions and transitioning towards "bit banging" so to speak was a step in the right direction.  Also, I am surprised that the BF bit is "read only."  I could've swore for the life of me that it was user accessible.  Nonetheless, you are correct and that has helped me as well.  Since last we spoke, I have almost completely dumped my i2c slave and started out fresh.  Upon looking at your slave, I never thought to look for a stop condition.  I have just now been able to look for your response and have already attacked the problem from a new angle.  But, clearing the buffer by reading it to a dummy variable works just fine.
I greatly appreciate your help!
Jim
	Original Post ID: 6951 |
