Also ? about write_bank
RT
PostPosted: Wed Nov 14, 2001 4:37 pm     Reply with quote
If you write a value to ram using the write_bank function from a function outside of main():
a) Is that value preserved by the PIC, or can it be overwritten?
ie:
main()
write_funtion(); //Will this print 65
void write_funtion()
write_bank(3,0,0x65);
printf("\%u",read_function());
void read_function()
int hex_sixty_five;
hex_sixty_five = read_bank(3,0);
return hex_sixty_five;
b) Does this save RAM because it seems to not increase my RAM usage if I use it instead of an array?
___________________________
Original Post ID: 1107
Neutone
Re: Also ? about write_bank
PostPosted: Wed Nov 14, 2001 5:55 pm     Reply with quote
Local variables are not perserved between function calls but your not talking about variables your talking about RAM locations. I would guess that your RAM usage report is based on RAM assigned to variables and does not account for directly addressed RAM.
:=If you write a value to ram using the write_bank function from a function outside of main():
:= a) Is that value preserved by the PIC, or can it be overwritten?
:=ie:
:=main()
:= write_funtion(); //Will this print 65
:=void write_funtion()
:= write_bank(3,0,0x65);
:= printf("\%u",read_function());
:=void read_function()
:= int hex_sixty_five;
:= hex_sixty_five = read_bank(3,0);
:= return hex_sixty_five;
:= b) Does this save RAM because it seems to not increase my RAM usage if I use it instead of an array?
Original Post ID: 1111
