Setting up adc channel
Nico van Luijk
PostPosted: Wed Jan 29, 2003 7:56 am     Reply with quote
Setting up the adc channel (set_adc_channel(n))seems to take quite a bit of processing time. I am trying to use 6 onboard A/D converters on the 18F452 while running at a clock speed of 40MHz. The sample frequency of each channel is around 20kHz. Is there a way of improving performance for the internal a/d converters or is this only possible by getting an external a/d converter?
Thanks.
Original Post ID: 11089
Neutone
Re: Setting up adc channel
PostPosted: Wed Jan 29, 2003 9:54 am     Reply with quote
:=Setting up the adc channel (set_adc_channel(n))seems to take quite a bit of processing time. I am trying to use 6 onboard A/D converters on the 18F452 while running at a clock speed of 40MHz. The sample frequency of each channel is around 20kHz. Is there a way of improving performance for the internal a/d converters or is this only possible by getting an external a/d converter?
:=Thanks.
Have a look at this thread I had to work with a simlar problem.
<a href="http://www.pic-c.com/forum/general/posts/9174.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/9174.html</a>
Original Post ID: 11094
Hans Wedemeyer
PostPosted: Thu Jan 30, 2003 7:17 am     Reply with quote
6 channels each sampled at 20kHz means a conversion every
1/120000 = 8.3uS
Reading the data sheet(DS39564A-page 183), and using the example shown "THE MINIMUM REQUIRED ACQUISITION TIME"
The example values are reasonable for real life situations, and as you can read the ACQUISITION TIME is about 12uS
In other words 6 channels at 20kHz per channel can't be done using the internal ADC. The best you could do is about 13kHz per channel and that is assuming you have zero overhead in code after the conversion. Of course you need to do something with the data, so zero is not practical !:-)
Best look at external ADC, Linear and MAXIM have several that could do the job.
I'm just in the middle of a design for 4 channels each channel to convert 12 bit at 100kHz per channel. The design connects to a PC via USB1.1 and total bit rate is about 6.4 megabits.
The PIC18F452 is so busy it's not possible to do much other than conversions and ship data.
I considered using a Scenix, and may still have to go that way if the client requests any more "extra features", as it is PIC18F452 is very busy...... !
Original Post ID: 11134
Nico van Luijk
PostPosted: Mon Feb 03, 2003 3:40 am     Reply with quote
:=6 channels each sampled at 20kHz means a conversion every
:=1/120000 = 8.3uS
:=Reading the data sheet(DS39564A-page 183), and using the example shown "THE MINIMUM REQUIRED ACQUISITION TIME"
:=The example values are reasonable for real life situations, and as you can read the ACQUISITION TIME is about 12uS
:=In other words 6 channels at 20kHz per channel can't be done using the internal ADC. The best you could do is about 13kHz per channel and that is assuming you have zero overhead in code after the conversion. Of course you need to do something with the data, so zero is not practical !:-)
:=Best look at external ADC, Linear and MAXIM have several that could do the job.
:=I'm just in the middle of a design for 4 channels each channel to convert 12 bit at 100kHz per channel. The design connects to a PC via USB1.1 and total bit rate is about 6.4 megabits.
:=The PIC18F452 is so busy it's not possible to do much other than conversions and ship data.
:=I considered using a Scenix, and may still have to go that way if the client requests any more "extra features", as it is PIC18F452 is very busy...... !
Thanks for your help. I assumed the A/D was a sample and hold and therefore that the conversion time (12xTosc) would be a one off each cycle for all channels. As you said external A/D converter is probably the best option.
I am not to sure if the 18f452 will be quick enough to do the job, I am probably going to use the 18f452 together with a Analog Devices DSP
Original Post ID: 11224
Nico van Luijk
PostPosted: Mon Feb 03, 2003 7:15 am     Reply with quote
:=1/120000 = 8.3uS
By the way the example you are using sampling 4 channels at 100kHz, what kind of protocol do you use, spi/i2c? Because the driver that CCS supplies for the MCP3208 is not particulary fast. Do you maybe have an example driver? thanks
Original Post ID: 11228
