MPLAB 6.10.10 and CCS compilers
Aryldo G Russo Jr
PostPosted: Mon Jan 27, 2003 10:17 am     Reply with quote
Hi everyone,
Have anyone tried the CCS compiler with MPLAB?
I intend to buy CCS, but I'd like to receive some comments about this subject.
Dinho
Original Post ID: 11032
Trampas Stern
Re: MPLAB 6.10.10 and CCS compilers
PostPosted: Mon Jan 27, 2003 11:19 am     Reply with quote
I use the MPLAB 6.10.10 with CCS sort of. I use an external editor for all my edits then compile and program in MPLAB using the ICD 2.
I have noticed that MPLAB is not "stable" so if you use it save often.
Trampas
:=Hi everyone,
:=Have anyone tried the CCS compiler with MPLAB?
:=I intend to buy CCS, but I'd like to receive some comments about this subject.
:=Thanks
:=Dinho
Original Post ID: 11035
Aryldo G Russo Jr
PostPosted: Mon Jan 27, 2003 11:26 am     Reply with quote
which external editor do you use?
Dinho
:=I use the MPLAB 6.10.10 with CCS sort of. I use an external editor for all my edits then compile and program in MPLAB using the ICD 2.
:=I have noticed that MPLAB is not "stable" so if you use it save often.
:=Trampas
:=:=Hi everyone,
:=:=Have anyone tried the CCS compiler with MPLAB?
:=:=I intend to buy CCS, but I'd like to receive some comments about this subject.
:=:=Thanks
:=:=Dinho
Original Post ID: 11040
Trampas Stern
PostPosted: Mon Jan 27, 2003 6:06 pm     Reply with quote
I use CodeWright. It allows you to define custom keyword highlighting for the preprocessor and built in functions.
Other good editors are:
VaPad - free www.wholetomato.com\vapad
UltraEdit - Cheap and good
I really like Visual Assist from www.wholetomato.com as an add in for visual studio. I hate to program with out it.
Trampas
:=Hi,
:=which external editor do you use?
:=Thanks
:=Dinho
:=:=I use the MPLAB 6.10.10 with CCS sort of. I use an external editor for all my edits then compile and program in MPLAB using the ICD 2.
:=:=I have noticed that MPLAB is not "stable" so if you use it save often.
:=:=Trampas
:=:=:=Hi everyone,
:=:=:=Have anyone tried the CCS compiler with MPLAB?
:=:=:=I intend to buy CCS, but I'd like to receive some comments about this subject.
:=:=:=Thanks
:=:=:=Dinho
Original Post ID: 11060
Warren Massey
PostPosted: Thu Feb 06, 2003 9:23 am     Reply with quote
:=Hi,
:=Thanks
:=Dinho
I use and am quite pleased with WinEdit
( <a href="http://www.winedit.com/default.asp" TARGET="_blank">http://www.winedit.com/default.asp</a> )
It has many nice features as an editor and does a good job understanding the "C" language.
Original Post ID: 11356
Lawrence Lile
PostPosted: Fri Feb 14, 2003 3:48 pm     Reply with quote
I would recommend against using MPLAB V6.1x with any compiler - there are too many issues as of yet. MPLAB V5.7.40 is nice and stable and works well with CCS.
However, I have experienced issues with network drives in both MPLAB versions. You will have the best luck storing your projects on a local hard drive when using MPLAB and also CCS.
I have produced commercial code for five years with the CCS compiler and this code is running in literally millions of consumer products. I recommend you buy it if you need a C compiler.
--Lawrence
:=Hi everyone,
:=Thanks
:=Dinho
Original Post ID: 11703
