to wake from sleep
nathan
Help with useing interrupt on portB to wake from sleep
PostPosted: Wed Aug 29, 2001 11:24 am     Reply with quote
My program is very simple, I have two switch inputs (RB1 & RB2) tied high, switch takes it low, with two outputs to drive a motor (RB4) and buzzer (RB5). I am using a F873. I have a proto circuit made an now my client wants the device to go to sleep to conserve battery energy. So I would like to use the sleep() command and use the change_RB or INT_RB to create an interrupt to wake from sleep.
I would like to do this by tying RB1 to RB6 and tie RB2 to RB7. This would allow me to wake from sleep and go to the correct portion of the program (I believe). I am not sure how to set things up to do this. I am not sure how or what to use as the RB_isr() in my program and what other things I should have set up. I do disable the WDT when I program the part.
Here is the code that I am using now and I am not getting it to work correctly. Does anyone have any suggestion? Thank you for any help that you can give.
// Program: camera_rx.c
// Date: 08-04-2001
// Rev. 03
#case
#include "16f873.h"
#use Delay(clock=4000000)
#use fast_io(B)
#define BUZZER PIN_B5
#define MOTOR PIN_B4
#define N_SW PIN_B2
#define TM_SW PIN_B1
#INT_RB
main()
disable_interrupts(GLOBAL);
//enable_interrupts(RB_CHANGE);
enable_interrupts(INT_RB);
//setup_counters(RTCC_INTERNAL, WDT_2304MS);
//ext_int_edge(H_TO_L);
//port_b_pullups(FALSE);
set_tris_b(0b11001110);
output_low(MOTOR);
output_low(BUZZER);
//sleep();
delay_ms(25);
//restart_wdt();
if ((input(N_SW)==0) || (input(TM_SW)==0))
if (input(N_SW)==0)
output_high(MOTOR);
delay_ms(200);
output_low(MOTOR);
restart_wdt();
restart_wdt();
restart_wdt();
restart_wdt();
while(input(N_SW)==0)
restart_wdt();
sleep();
if (input(TM_SW)==0)
restart_wdt();
output_high(BUZZER);
output_low(BUZZER);
restart_wdt();
restart_wdt();
restart_wdt();
restart_wdt();
restart_wdt();
restart_wdt();
restart_wdt();
output_low(BUZZER);
restart_wdt();
output_low(BUZZER);
restart_wdt();
restart_wdt();
output_high(MOTOR);
delay_ms(200);
output_low(MOTOR);
restart_wdt();
restart_wdt();
while(input(TM_SW)==0)
restart_wdt();
sleep();
restart_wdt();
Original Post ID: 89
Neutone
to wake from sleep
PostPosted: Thu Aug 30, 2001 2:45 pm     Reply with quote
enable_interrupts(INT_EXT); // enable interupt on B0
ext_int_edge( H_TO_L ); // trigger on falling edge to wake up
sleep(); // Excecute sleep
#asm
BCF 11,1 // Clear B0 interupt
#endasm
Because there is no interupt routine the code picks up where it left off. Clear the interupt to you can put it to sleep. It will not sleep unless the interupt has been cleared.
Original Post ID: 109
